Actually what it says is:
NOTE: for older versions (prior to 1.3.x), try changing the line:
to read:Code:class usps extends base {
That should work on any version that cannot use the extends base on the module ...Code:class usps {
thank you for that post! I was having the same problem too with the percentages. Hopefully your suggestion will work.
Be sure to check the current updates for the January 4, 2010 module as there have been some changes as of January 12, 2010 ...
http://www.zen-cart.com/forum/showthread.php?t=144992
thanks for getting this module updated and running so quickly!!
i do see that our international customers are still having an issue with the onces being more than 5 digits when they order more than 1 item
"-2147218052 - The ounces field must be less than 5 digits"
i have the latest greatest module installed and i uninstalled and reinstalled it once i uploaded the new file (jan 9th file).
any ideas why this is not working? your help and replies are always very very appreciated!!
Odd ... could you give me the Product weight and the Tare settings that you are using so this can be tested?
Also what are your USPS settings?
Hi Linda.
I'm having problems getting the correct usps shipping charges for first class shipments.
If I go to usps.com to get a rate for a 6oz package shipping from 48042 to 30094 I get a quote for $1.73
If I try to get a quote from my store (www.byvalenti.com) the shipping estimator gives me a much higher amount $2.41.
I've spent an hour looking for an answer and haven't been able to find anything. I already updated the usps.php file. My settings are:
Shipping Module
Enable USPS Shipping
True
Enter the USPS Web Tools User ID
XXXXXXXXXXXX
Which server to use
production
Handling Fee
Handling Per Order or Per Box
Box
Tax Class
--none--
Tax Basis
Shipping
Shipping Zone
--none--
Sort Order
All Packages are Machinable
True
USPS Options
Display weight, Display transit time
Domestic Shipping Methods
EXPRESS, PRIORITY, FIRST CLASS, PARCEL
International Shipping Methods
Global Express, Global Express Non-Doc Rect, Global Express Non-Doc Non-Rect, Express Mail Int, Express Mail Int Flat Rate Env, Priority Mail International, Priority Mail Int Flat Rate Env, Priority Mail Int Flat Rate Box, Priority Mail Int Flat Rate Small Box, Priority Mail Int Flat Rate Med Box, Priority Mail Int Flat Rate Lrg Box, First Class Mail Int Lrg Env, First Class Mail Int Package, First Class Mail Int Letters, First Class Mail Int Flats, First Class Mail Int Parcels
Debug Mode
Off
Shipping/Packaging
Enter the Maximum Package Weight you will ship
50lb
Package Tare Small to Medium - added percentage:weight
0:0
Larger packages - added packaging percentage:weight
0:0
Thanks for any help.
M.Valenti
Contemporary Artist - Entrepreneur
http://www.manuelavalenti.com - http://www.byvalenti.com
The only way I can get the wrong value is if I have:
All Packages are Machinable: false
Could you go to the Tools ... Developers Tool Kit ... and in the bottom input box enter:
usps.php
What version comes up in the:
/includes/modules/shipping/usps.php
Can you save your settings and do a REMOVE, INSTALL and reconfigure it?
NOTE: there was an update done on January 9, 2010 and for International, one more change on January 12, 2010:
NOTE: these are the rates I get via Zen Cart
United States Postal Service (1 x 0.38lbs) (Express Mail (1 - 2 days)) $19.35
United States Postal Service (1 x 0.38lbs) (First-Class Mail (2 - 5 days)) $1.73
United States Postal Service (1 x 0.38lbs) (Priority Mail (2 - 3 days)) $5.05
United States Postal Service (1 x 0.38lbs) (Parcel Post (4 - 7 days)) $4.90
United States Postal Service (1 x 0.38lbs) (Media Mail) $2.38
United States Postal Service (1 x 0.38lbs) (Bound Printed Matter) $2.43
United States Postal Service (1 x 0.38lbs) (Library) $2.26
NOTE: these are the rates I get with Zen Cart with the Machinable set to false:
United States Postal Service (1 x 0.38lbs) (First-Class Mail (2 - 5 days)) $2.07
Thank you for the quick reply.
I have the latest version of the usps.php file * @version $Id: usps.php 15202 2010-01-09 21:31:35Z ajeh $
I uploaded the file again, removed and reconfigured, now I'm getting these quotes with machinable set to true or false, weird, they don't change and I know they should:
United States Postal Service (Express Mail (1 - 2 days)) $19.35
United States Postal Service (First-Class Mail (2 - 5 days)) $2.07
United States Postal Service (Priority Mail (2 - 3 days)) $5.05
United States Postal Service (Parcel Post (4 - 7 days)) $4.90
Are there any other files I should check aside from the usps.php file?
M.Valenti
