Page 3 of 17 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 169
  1. #21
    Mar 2005
    Default
    ok finally everything is fixed. The two things that needed to be done was I needed to change the index name to forumindex in the filenames file, and change the value in the configure.
  2. #22
    Mar 2005
    Default
    ok another question how can I add a button at the top just for the forums?
  3. #23
    3
    Default
    copy-and-paste the link from your site into the tpl_header.php page you're currently using.
    /includes/templates/YOURTEMPLATE/common/tpl_header.php
  4. #24
    Mar 2005
    Default
    ok I opened the file and where in the world do I put the link at in that file? I don't see any where in that file to put it at.???????????????????????????????
  5. #25
    3
    Default
    That file is just a nest of table cells.
    There are tons of posts elsewhere (this is a phpBB thread) that talk about customizing that file. You can do a search for "tpl_header.php" in the search box in the top left corner of this page...
  6. #26
    May 2004
    Default
    Originally posted by DrByte@Feb 7 2005, 10:44 PM
    NOTE: The above details do NOT include instructions on how to assign/edit phpBB account info for existing customers.
    Anyone have any tips on assigning existing phpbb users?
    I have close to 2000 phpbb members & would like to tie thier forum accounts to zencart upon registration into zencart.
    any ideas?
    3
    Default
    The logic for creating phpBB users is in
    /includes/modules/pages/create_account/header_php.php
    You could modify that code to first check for a user by that email address in phpBB and link them together at that point.
    You should also then compare the Nickname they enter in create-account vs the phpBB username and make sure that both the username and email address match. Assuming they do, sync the password from zen into phpBB, and proceed from there.
  8. #28
    Jun 2005
    Default
    Is there any way to Link
    SMF Forums to Zen - it shouldn't be to hard to do
    if someone just tell me how or what files to edit - ill make the needed changes to it myself
    but im not sure where the programming is for its linkage
    anyone?
  9. #29
    3
    Default
    The logic for how phpBB integrates is being split out into a logically separate class for v1.3
    It's presently split out into several header_php.php files and the sniffer.php class file.
    search for $sniffer->phpBB function calls, etc
    As I mentioned, v1.3 will have it all separated out so that other forums could be coded manually in a single php file ... or at least that's the plan...
  10. #30
    Jun 2005
    Default
    Well thx for the info
    I got another question
    is there such a module for Monthly Re-occuring Payments - that can be setup to use PayPal
    cuz Zen cart is everything i need - except a reoccuring module
    if it had that it would be PERFECT
