Page 15 of 25 FirstFirst ... 51314151617 ... LastLast
Results 141 to 150 of 244
  1. #141
    Apr 2005
    Default Re: Ceon Manual Card Payment Module v2.0.0!
    Quote Originally Posted by conor View Post
    I think Zen Cart should then be fine with sending multiple e-mails by simply having commas between the addresses.
    All the best..
    Conor
    ceon
    Thanks a lot! At the moment I'm up to my eyeballs in trojan's etc on a users pc, but I'll try this out asap.
  2. #142
    Apr 2005
    That works perfectly. Thanks Conner. I'll be sure to only use it as a last resort.
  3. #143
    Oct 2010
    Have you followed the instructions and created the database table?
    If so, that file missing would be the or your database settings in configure.php being wrong would be the ONLY reasons that you'd get that message.
    All the best..
    Conor
    ceon
    I'm having the same issue. (I'm a SQL newbie, too. As in, never really looked at it until today.)
    Even so, I'm certain I'm SO...CLOSE...to getting it working, but I'm stymied:
    1. I read the FAQ and the instructions. I created a new SQL database. I made sure the file "includes/configure.php" showed the right database name.
    2. I used "Tools - Install SQL Patches" to upload "ceon_manual_card.sql" and then "ceon_manual_card_upgrade_from_1.x.sql". I didn't type anything into the big text field, I just uploaded the files specified. Or installed them. Or whatever it is you do to create a table in a database. I guess.
    When listing payment modules, it shows "Ceon Manual Card v2.0.0" (YAY) but Zen Cart says: "The Ceon Manual Card Database Table Does Not Exist!" (boo)
    3. I looked in the SQL database and I have a table called "ceon_manual_card", but it doesn't seem to be "active" or have anything in it. Not sure how to fix that.
    Read the FAQ again. Read this thread. Utterly stuck.
    Conor said:
    "If so, that file missing would be the or your database settings in configure.php being wrong would be the ONLY reasons that you'd get that message."
    "...that file missing would be the problem..."?
    Help?
  4. #144
    Aug 2004
    Belfast, Northern Ireland
    Quote Originally Posted by lbentleyGI View Post
    Yes, that's the problem. Upload ALL of the module's files again. You have missed some out.
    All the best..
    Conor
    ceon
  5. #145
    Oct 2010
    All the best..
    Conor
    ceon
    I had other problems, too, so I simply deleted everything from the server and reinstalled, and this time I copied the Ceon files into the correct directories before uploading them to the server, and that seems to have worked perfectly. Thanks very much!
  6. #146
    Aug 2010
    GoDaddy just told me that Crypt_Blowfish is not compatible with their system, that they tried installing it and it did not work. This seems a bit odd to me and I suspect there is a bit of a problem with having to talk to a tech person who has never heard of it who then has to talk to someone else. Does anyone have Crypt_Blowfish working on GoDaddy so I can go back to them and say "see!"
    I know GoDaddy is not the favorite of Zenners, but this is where I am for now.
    Thanks for your help.
  7. #147
    Aug 2004
    Quote Originally Posted by Euonym View Post
    You can follow the instructions in the FAQs to install the files manually (FTPing them up to your store's directories as appropriate).
    Or you can wait for version 3.0.0, which removes the need for the PEAR and PEAR:Crypt_Blowfish files.
    In the meantime you can simply disable the storage of details, so you don't need PEAR:Crypt_Blowfish. It's less convenient for your customers as they'll have to re-enter their details if they leave the payment page and come back to it, but it's only a temporary situation, until 3.0.0 is out.
    Version 3.0.0 should hopefully be out at the end of next week or early the week after; please, everyone, don't ask "when will 3.0.0 be out?" - I won't respond to any such question.
    All the best..
    Conor
    ceon
  8. #148
    Mar 2010
    Connor, Connor, when will ...
    I'll get me coat ;-)
  9. #149
    Aug 2010
    Thank you Conor. I think I'll wait for 3.0.0.
  10. #150
    Aug 2004
    Quote Originally Posted by nickgreaves View Post
    When I saw that there was such a quick reply my first thought was "I bet someone's written 'when will 3.0.0 be out?'".
    We have a winner.. it's Nick! :)
    Enjoy the rest of your weekend!
    Happy Halloween!
    Conor
  1. Ceon Manual Card Payment Module v4
    By conor in forum Addon Payment Modules
    Last Post: 19 Jan 2017, 05:01 PM
  2. Ceon Manual Card Payment Module v3.0.0
    Last Post: 15 Nov 2012, 06:36 PM
  3. Ceon manual card module - cc error leads to page not found
    By jenniesummitreks in forum Addon Payment Modules
    Last Post: 16 Sep 2009, 09:28 PM
  4. Ceon Manual/Offline Card Payment Module v1.0.0!
    Last Post: 27 Feb 2009, 10:04 PM
  5. Re: Ceon Manual/Offline Card Payment Module v1.0.0!
    By wizarddave in forum Addon Payment Modules
    Last Post: 2 Jan 2008, 05:13 PM
