I reverted to the backup from prior to the Ceon install and all works well, including the storeadmin/index.php.
The instructions state:
I'm confused over that statement. I copied the ceon files store/includes/* to store includes/* and admin/includes/* into the storeadmin/includes/*. I think, into the proper folders.Please Note: If the admin folder for the store is not named “admin”, then care must be taken to place the files from within the files/admin folder into the store's admin folder. Simply copying across the files/admin folder won't work!
I'm confused because the instructions state:
New Files
Still no idea.These are the files which make up this module. They should be copied into their respective folders in the Zen Cart installation.
They already have the correct folder structure, so a single drag-and-drop of the folders/files in the files folder into the root directory for the store will put the files in the correct locations.
There's no need to copy the files individually - that often results in files being missed out!
[/FONT]
There there any easy tutorial or any someone break it down in baby steps for a newbie to learn how to install this? I download the software and don't know which sniplet goes where? I try youtube but they don't have a tutorial.
