Page 5 of 21 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 210
  1. #41
    Apr 2009
    Portland, Oregon
    Default Re: snap-affiliates?
    Has anyone been able to make Snap Affiliates play nice with the SSU (Simple SEO Urls) module? The problem i'm having is with the referral links and the fact that they need to be re-structured to work through SSU's mod-rewrite of URLs.
  2. #42
    May 2006
    Yeah, you would need to change the URL for using SEO
    instead of ABC.com/&referrer=CNWR_11280387020
    The correct one would be ABC.com?referrer=CNWR_11280387020
  3. #43
    Jan 2010
    I am experiencing the same problem as buildingblocks:
    Once I input an address to submit I get this page....
    1054 Unknown column 'REFERRER_DEFAULT_COMMISSION' in 'field list'
    in:
    [insert into referrers (referrer_customers_id, referrer_key, referrer_homepage, referrer_approved, referrer_banned, referrer_commission) values(24,"REFERRER_KEY_PREFIX241280770555","www.testaffiliates.com", 0, 0, REFERRER_DEFAULT_COMMISSION)]
    So, where can I go from here. I am using 1.3.8a and have used the sql file accordingly by copy/paste/send and have installed everything properly to my knowledge.
    I am stuck at this point. I'm not seeing where buildingblocks fixed this.
    Jan 2010
    To expand upon the above in my last post. I would like some clarification on the "Edit the includes/snapconfigure.php file to reflect your site preferences."
    Maybe that's it.
    Thanks again
  5. #45
    Jan 2010
    Fix to the above...
    OK - So it seems to be version 1.0.2 that you want found on the creators website - I had 1.0. The file that I had to swap out was \includes\modules\pages\referrer_signup\header.php
    That seemed to get rid of that fault when signing up.
  6. #46
    Jan 2010
    This mod works great!
    I am trying to add customer name to the referrer page in admin when an order is displayed for that referrer's commission. I have the layout in the table correctly, but need better code to actually display the customer's name in the currently blank field. Here is my current code:
    This is what I added to the below, what I am missing here?
    printf("<tr>\n");
    printf("<td class='%s'>\n", $toggle ? "historyA" : "historyB" );
    printf("%s\n", $order['customer_name']);
    foreach( $referrers[$selected]['orders'] as $order ) {
    $total = floatval( $order['order_total'] ) - floatval( $order['value'] );
    $commission = floatval( $order['commission_rate'] );
    if( $total < 0 ) {
    $total = 0;
    printf("<tr>\n");
    printf("</td>\n");
    printf("%s\n", $order['date_purchased']);
    printf("</td>\n");
    Jun 2007
    Bronx, New York, United States
    Quote Originally Posted by thelawman View Post
    I had the same issue with the email error.
    Try editing the includes/modules/pages/referrer_signup/header.php file line 56 from 'admin_level = 1' to 'admin_level = 0' or you can do what I did and create a second admin user called Affiliate Manager with a new email address (I used affiliate_manager@mydomain.com) and left the code as is at 'Admin_Level = 1 '
    The pay button is for a manual pay system, i.e you send them a check or PayPal, etc. and then click the button to change the status.
    For me... when an email is sent to the affiliate all it says is
    I'm running into the same problem here...
    I edited the functions_email.php file to echo the filename being used for the template...
    The logic is obviously correct but here's the weird thing:
    C:/Program Files/Abyss Web Server/htdocs/zencart/email/email_template_referrer_banned.html
    C:/Program Files/Abyss Web Server/htdocs/zencart/email/email_template_default.html
    It's outputting BOTH the default AND the name of the file that I want to use. Obviously, something is wrong here...
  8. #48
    Jun 2007
    And after some time looking into this... I figured it out.
    Evidently, if you are using Plain Text.. You'll get this looking the right way... however, if you're HTML... You're screwed.
    So here are the edits you'll need to make, some might be redundant but feel free to let me know (so that I can change mine as well)
    You'll need to make these changes to admin/referrers.php
    1. Look for
      function send_notification_email($referrer$subject$text) {
    2. Change this to
      function send_notification_email($referrer$subject$text$block$module_used) {
    3. Look for
            zen_mail($customer['customers_firstname'] . " " $customer['customers_lastname'],
    4. Now, this one is tricky. In this code block you need to make some changes here... after $admin['admin_email'] add and a comma (,) and then this
                 $block,           $module_used
    5. Now when you're ready... find
                     "Your " TITLE " referrer account has been approved!",
      $main_body
    6. Then after $main_body add a comma, and then add:
                     $content_map,
      "referrer_approved"
    7. Now find
                       "Your " TITLE " referrer account has been suspended.",
      $main_body
    8. After $main_body, add a comma then add
                       $content_map,
      "referrer_banned"
    9. Lastly find,
                     "Your " TITLE " commission payment has been made.",
      $main_body
    10. Then add a comma after $main_body, then add
                     $content_map,
      "referrer_paid"
    And After this you should have emails being sent to people that aren't using EMAIL_TEMPLATE_DEFAULT.PHP but the right one.
  9. #49
    Jun 2007
    Something to work on:
    - Ability to edit details in ACP.
    - Ability to deny applications in ACP.
    - Ability to edit details on the customer side. (Some might change websites.)
    - Ability to add "Where to send my check?"
  10. #50
    May 2010
    Thanks for working on the email issues retched and please keep posting your fixes!!!
    The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
  1. Snap Affiliates Module?
    By asauterChicago in forum All Other Contributions/Addons
    Last Post: 12 Apr 2013, 09:45 AM
  2. Affiliates
    By barrystein in forum General Questions
    Last Post: 8 Feb 2009, 01:45 AM
  3. How to: Affiliates ??
    By marbles in forum Customization from the Admin
    Last Post: 17 Jun 2008, 04:22 PM
  4. OH SNAP -- Locked out of Zen Cart Admin
    By smallarmsdealer in forum Templates, Stylesheets, Page Layout
    Last Post: 18 Nov 2007, 05:12 AM
