Results 1 to 10 of 10
    Nov 2009
    Boston, MA
    Default Need to display Zen-cart products inside a div
    I'm trying to display Zen-cart products inside a div. Is that possible? How would one go about doing that?
    Or do I need to build my layout AROUND Zen-cart's layout?
    I would really appreciate any help or advice you could offer. Thanks in advance!
    Feb 2005
    Lansing, Michigan USA
    Default Re: Need to display Zen-cart products inside a div
    A little more information, please. Are you trying to use parts of Zencart inside another site? If so, it's not a good idea. Zencart is intended to be, and works best as, a stand-alone application.
    Nov 2009
    Boston, MA
    I'm basically just trying to have a page with a vertical nav on the left listing all of the product categories (I've created this nav), and I want it so when you click a category it loads and my vertical nav stays on the page, instead of going to JUST a zencart products page.
    Do you know how I could do that?
    Feb 2005
    I might be able to do it (if I understand the question), but I wouldn't. Let's see a link to your site.
    It's important to realize that Zencart can't be a back-end cart script for your existing site.
    Nov 2006
    Dartmouth, NS Canada
    Quote Originally Posted by Ryan Greenlife View Post
    What you'vce just described is the normal behaviour of Zen Cart. So I'm as confused as stevesh. What exactly have you done so far? A link to your site would be very useful to us in helping you.
    Rob
    Nov 2009
    Boston, MA
    This is the page with my menu on it:
    http://www.greenlifegardensupply.com/indexcopy.html
    As you can see, when you click on a category it leads you to a zen-cart-only page which displays the products. I need to get the menu I made into the zen-cart layout, so it is on the same page as the listed products.
    What do you think you're gaining by building your pages from scratch when you could achieve the identical appearance and functionality (and more) by modifying the Zen Cart template?
    Feb 2005
    That wouldn't be that difficult to recreate in Zencart.
    One of the issues you may have doing it your way is the possibility of sessions problems when switching back and forth between Zencart and non-Zencart pages.
    You would have to recreate the Categories sidebox by creating the categories and products in Zencart admin, and if you're going to do that, you may as well make the whole thing Zencart.
    Nov 2009
    Boston, MA
    I don't NEED to have it all in a new page that I created if that's not going to work. I guess my question, then, is how do I change the Zencart template to have my menu in it?
    What file do I have to add my menu to?
    Feb 2005
    You don't. You'll need to stop thinking in terms of static HTML pages and start thinking about dynamic PHP pages that are built on the fly. (That's not a criticism - we all had to make that leap in the beginning.)
    You'll create your categories in Zencart by adding them and your products in Admin - Catalog.
  1. How to display products inside a defined page?
    By whosleonard in forum General Questions
    Last Post: 7 Mar 2011, 04:23 PM
  2. Using Zen Cart for Secret Santa? Details Inside.
    By solarguy in forum General Questions
    Last Post: 29 Sep 2010, 08:09 PM
  3. Running Zen-Cart in a <div>
    By kontron in forum Templates, Stylesheets, Page Layout
    Last Post: 17 Feb 2009, 11:53 PM
  4. Installing a Photo gallery that opens inside Zen Cart
    By jgatlin in forum General Questions
    Last Post: 16 Jun 2008, 01:25 AM
  5. Open external page inside Zen Cart
    By Moskovo in forum General Questions
    Last Post: 7 May 2008, 11:29 PM
