Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Default Re: Show Out of Stock Products Doesn't Work
    Go to the Tools ... Developers Tool Kit ... and in the bottom input box do a search on:
    STOCK_MARK_PRODUCT_OUT_OF_STOCK
    and select Catalog and click SEARCH ...
    See what files, other than the PayPal files, reference this ...
  2. #22
    Sep 2011
    below is the list of files.
    /catalog/includes/functions/functions_lookups.php
    Line #241 : $out_of_stock = '<span class="markProductOutOfStock">' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . '</span>';
    Line #255 : $out_of_stock = '<span class="markProductOutOfStock">' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . '</span>';
    Line #258 : $out_of_stock = '<span class="markProductOutOfStock">' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . '</span>';
    /catalog/includes/languages/english/Rumina/checkout_confirmation.php
    Line #27 : define('OUT_OF_STOCK_CAN_CHECKOUT', 'Products marked with ' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . ' are out of stock.<br />Items not in stock will be placed on backorder.');
    /catalog/includes/languages/english/Rumina/shopping_cart.php
    Line #23 : define('OUT_OF_STOCK_CANT_CHECKOUT', 'Products marked with ' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . ' are out of stock or there are not enough in stock to fill your order.<br />Please change the quantity of products marked with (' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . '). Thank you');
    Line #24 : define('OUT_OF_STOCK_CAN_CHECKOUT', 'Products marked with ' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . ' are out of stock.<br />Items not in stock will be placed on backorder.');
    /catalog/includes/languages/english/checkout_confirmation.php
    Line #26 : define('OUT_OF_STOCK_CAN_CHECKOUT', 'Products marked with ' . STOCK_MARK_PRODUCT_OUT_OF_STOCK . ' are out of stock.<br />Items not in stock will be placed on backorder.');
    /catalog/includes/languages/english/shopping_cart.php
  3. #23
    It shows at quantity 83 ... maybe there is some issue on your Add on if it is not working correctly for this attribute combination ...
  4. #24
    Sep 2011
    I have 83 for that style, but the black large is zero.
    so I would think that on the line of the large black in the shopping cart it would say "out of stock" at that line as well as the top.
    Below is how I have the attributes set up.
    38 TEXT + 0.0000 + 0 0
    Display Only Free Default Discounted Base Price Required
    $0.00 $0.00 Update Delete
    Delete Color
    37 Color White + 0.0000 + 0 1
    36 Color Black + 0.0000 + 0 2
    Delete Size
    32 Size Small + 0.0000 + 0.4625 1
    34 Size Large + 0.0000 + 0.38 3
    35 Size X-Large + 0.0000 + 1 4
  5. #25
    Might try posting on the support thread for that add on plugin and see if anyone has a solution or possible cause to the problem ...
  6. #26
    Sep 2011
    OK, I found the issue I was having. I followed your suggestion and went to that plugin and got the latest update. 1.4.14, the problem was in the "includes\modules\pages\shopping_cart\header_php.php" file. I updated that file and now it show the item that is out of stock. There is I think a new small bug. if I select an item that is out of stock, and do not delete the first item, then add a different item to the cart then that item shows out of stock as well.
    Any suggestions?
  7. #27
    Same as before ... I do not use this add on plugin so check with the support thread for it ...
  8. #28
    Dec 2012
    What that setting does is that when an order is made and the products_quantity falls to <= 0 the products_status is set to 0 which makes the Product be "Out of Stock" meaning not show in the Catalog ...
    Changing that setting only affects Products based on future Orders ... it does not change the current setting for the products_status on Products where products_quantity <= 0 ...
    You can do this manually or you could run this SQL in the Tools ... Install SQL Patches ...
    UPDATE products SET products_status = 0 WHERE products_quantity <= 0;
    NOTE: make a backup of your database before running commands like this ...
    Linda - I have pre-populated the cart with products, some with quantity in stock and some with "0" quantity (showing Out of stock in the catalog).
    Now, shop owner realizes that he does NOT want to show products Out of Stock in the catalog.
    I have gone under “Admin>Configuration>Stock” and change the following variables:
    Products status in Catalog when out of stock should be set to 0.
    Reading this thread tells me that if a product has been added in the past to the catalog with “0” quantity, by changing the setting in “Admin>Configuration>Stock> Products status in Catalog when out of stock should be set to “0”” would not have an effect on product disappearing from the catalog. I understand this and it is replicated on the site.
    My question:
    When you add a new product with “Products Quantity: 0” and “Products Status: In Stock:”, then the product would show in the catalog as “Out of Stock”. So by changing the “Admin>Configuration>Stock> Products status in Catalog when out of stock should be set to “0””, the “Out of Stock” status in the catalog will show anyways, Correct?
    Then the only use that “Admin>Configuration>Stock> Products status in Catalog when out of stock should be set to “0”” is when you have 1 or more products for “Products Quantity:”, and as customers purchase the product and the stock quantity becomes 0, then it will changes the product’s “Products Status: Out of Stock:”, making it disappear from the catalog. Correct?
    My conclusion is when populating the catalog with products, if the “Products Quantity: 0”, and you don't want to the "Out of Stock" Status, then you should check the “Products Status:" to "Out of Stock”, otherwise it will show in the catalog as "Out of Stock". And, the “Admin>Configuration>Stock> Products status in Catalog when out of stock should be set to “0”” has no auto functionality. Correct?
    Using Zen Cart 1.5.1
  9. #29
    Setting the Product Stock to be turned off ( 0 ) when quantity goes to <= 0 only affects Products during the completion of checkout ...
    That setting will not change current settings based on products_quantity <= 0, those have to be changed manually ...
    If you want to globally change ALL Products with products_quantity <= 0 to be turned off so that they do not show in the Catalog, you can run this in the Tools ... Install SQL Patches:
    NOTE: It is always a good idea to backup your database before running these types of changes ...
  10. #30
    Dec 2012
    Got it now. Thank you.
  1. Replies: 2
    Last Post: 8 Jun 2008, 07:06 PM
  2. Making Qty Discount work with Products with Attribute Stock mod.
    By Stenrique in forum Setting Up Categories, Products, Attributes
    Last Post: 6 Dec 2006, 01:45 PM
  3. New product not to show out of stock products
    By gardengate in forum Basic Configuration
    Last Post: 11 Sep 2006, 02:53 PM
  4. Reviews to Show for Out-of-Stock products
    By vera in forum General Questions
    Last Post: 21 May 2006, 01:48 AM
