Results 1 to 3 of 3
    Aug 2009
    Bedford, England
    Default Auto set sort order when products out of stock?
    Hi All,
    I use sort orders to place products in the order that I want them, however, it would be nice if before using the sort order I choose, it sent all out of stock products to the end, then all in stock products to use my specified sort orders at the front.
    I read a thread where someone had done something similar, however they simply set in stock at the front and out of stock at the back.
    I want the in stock items to still use the sort orders I specify and out of stock items to over-ride the sort I set to like 1000??
    Anyone know how I can achieve this/done this before?
    Phil
    Aug 2009
    Bedford, England
    Default Re: Auto set sort order when products out of stock?
    following the post I found, so far I have set
    $listing_sql .= " order by p.products_sort_order , pd.products_name";
    $listing_sql .= " order by p.products_sort_order , p.products_quantity desc";
    in /includes/index_filters/default_filter.php
    Now although this works, Here is an example why its not..
    prod1 - instock - sort 0
    prod2 - instock - sort 5
    prod3 - outstock - sort 0
    prod4 - outstock - sort 5
    here is how the current set up orders them:
    I need it to sort like this:
    Any suggestions how to get it to do what I want??
    Aug 2009
    Bedford, England
    haha I think I worked it out
    assuming im right
    i've just swapped which it sorts by first..
    so I now have
    $listing_sql .= " order by p.products_quantity desc, p.products_sort_order";
    instead of
    $listing_sql .= " order by p.products_sort_order, p.products_quantity desc";
    Is that right??
    also can I add more rules to it?
    like
    name, sort, quantity..
  1. Replies: 3
    Last Post: 17 Jan 2012, 08:20 AM
  2. Replies: 7
    Last Post: 10 Jun 2010, 10:43 AM
  3. Where do i globally set products sort order?
    By this side up in forum Setting Up Categories, Products, Attributes
    Last Post: 24 May 2007, 06:58 PM
