Okay based on this part:
if I DON'T need to convert, then I need to change edit the configure.php file and the english.php file BACK to the old characterset.. Am I understanding this correctly???edit your upgraded english.php file to use the old CHARSET and setlocale settings, as well as edit your configure.php file to set DB_CHARSET to 'latin1'
(if I am I have a followup question)
IF I need to convert, does the upgrade process upgrade the data and tables, or do I still need to run your conversion script??? (the one that's in the free downloads section)
My Site
Choosing your character set is *your* job, not Zen Cart's job. The zc_install upgrade process DOES NOT change your character set. That's up to you.
If your existing database is NOT in utf-8 then you'll need to change your Zen Cart language files and configure.php to use whatever character set you're using with your database.
For new installs, it's best to use utf-8 because it's generally more globally compatible and most hosts use it by default now, so a new store should also use it by default. That's why the Zen Cart distribution files are set to use utf-8 by default.
Again, if *you* can't or don't want to use utf8 for whatever reason (including because you're upgrading a store whose data is NOT already utf8) then you need to change the Zen Cart code/files/etc to NOT use utf8.
My Site
I have a problem with my Zencart 1.3.9h. I installed Zencart with UTF8 coding. The same with some people here, my Zencart could display Japanese characters correctly but in the MySQL DB, the characters show a mess. After I installed the following files, MySQL DB and Zencart shop both can display Japanese Characters correctly.
/includes/extra_configures/my_db_charset.php
/admin/includes/extra_configures/my_db_charset.php
However, a new issue happens. When I want to create a new account from shop page or input product information from admin page, the character become a mess. How can I resolve the problem?
I think I have the same problem with Nurapipi here
http://www.zen-cart.com/showthread.p...r-v1-3-x/page2
It seems Nurapipi resolved the problem by changing to another server, but is there any other way to resolve the issue? Because there are so many hosting service in the Internet and it is difficult to try all of them.
