Version 1.3.9b
Catalog -> Featured Products
Select a product from the list
Use the arrow alongside the available date field to pull down the calendar and select a date
Do the same for the expiry date
The dates in those fields now have a / at the beginning which means that when you click on "insert", dates in 2036 are entered instead of the correct ones. Removing the / from each field before clicking on "insert" makes it WAD.
I've read the thread at http://www.zen-cart.com/forum/showth...d+product+date regarding this problem. I have edited the two english.php files per https://www.zen-cart.com/tutorials/i...hp?article=401 so I went and checked through the relevant sections of each very carefully to see if I had made an error. I found none.
Dates elsewhere on the site - both in Admin and the Online Catalog - work fine.
Regards
Nick
