Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 95
    Sep 2005
    Waikato, New Zealand
    Default Re: Zen Cart Button Construction Kit 1.6.5 and up..
    Its not something i am currently looking at either, mainly as the sites i look after still have at least 30% ie6 usage, although it is dropping rapidly now, I will probably have a look at it again later in the year, but looking at the code it shouldn't be too difficult, it's just it isn't my code and i have got to get my head around all the code before making changes
    So for me just using a jpeg and setting the background colour to match the content background is all i need
    Aug 2007
    Gijón, Asturias, Spain
    Default version 1.6.6
    Version 1.6.6 (for php5.3) now available for download
    http://www.zen-cart.com/index.php?ma...roducts_id=743
    for those with 1.6.5 working on php 5.2 this version does not offer anything extra.
    Sep 2005
    Default Re: version 1.6.6
    Quote Originally Posted by torvista View Post
    I hate to be a party pooper
    You missed the buttons/swedish folder
    which means the swedish buttons won't generate
    Aug 2007
    I always miss something, this time I can blame it on jet lag instead of the kids.
    Quote Originally Posted by nigelt74 View Post
    Again no worries.. Just would be nice if this generated PNG buttons.. I have a great javascript I use to make them (PNGs) obey on IE6 that works very well.. For some designs I need buttons with transparent backgrounds.. I have a great graphics person I work with who does 'em for me in those instances..
    Anyway if you decide to give this feature a looksee, I'll look forward to seeing that improvement.. I'll still keep this tool in my arsenal as I do find it very useful for some designs.. Am I following this thread correctly in that there is one more modification and re-submission in the works??
    My Site
    Sep 2005
    Quote Originally Posted by DivaVocals View Post
    the only mod needed is to add a folder called swedish in the buttons directory, I assume torvista is already on to it or sleeping depending on where in the world he is at the moment
  7. #17
    Got it!! will update my current install..
    My Site
  8. #18
    Aug 2007
    Default png transparency
    Thanks to a pointer from nigel, this bit of code makes png backgrounds transparent, but that includes the text - some of the background seeps through. I think this is easy to fix but I have no time now, someone please investigate imagefilledrectangle etc..
    in class.zen_bck.php line 91
            imagefill($btn_body00$bgcolor);
    change to
    imagecolortransparent($btn_body$bgcolor);
  9. #19
    Sep 2005
    Default Re: png transparency
    yep thats about as far as I got
    provided you set the background colour to something almost the polar opposite of the font colour, i got virtually no bleed through, or at least none i noticed, its just a halo of background colour around the button that bugs me.
    see here
    http://grumpykiwi.com/zen_buttons/zen_bck/
    select "transparent test" in the defaults looks good on the red background, but when you actually create the buttons you see the red halo, provided you set the back ground colour to something similar to your site background, the buttons will fit in a heck of a lot better with the above hack, than they previously did
    I am looking at imagefilledrectangle, but, todays is my eldests 4th birthday so the will be a sugar crazed midget terrorist stopping me for the next few days
  10. #20
    Thanks to both of you.. Ya'll are the BEST!!! Will certainly give all of this a try this weekend (provided I can get folks to leave me alone with my geek toys..)
    Nigel are you familiar with the Super Sleight script?? I have had EXCELLENT success making PNGs in IE6 behave with this script in place.. No more blue halos..
    var supersleight=function(){var root=false; 	var applyPositioning=true; 	var shim='images/x.gif'; 	var shim_pattern=/x\.gif$/i; var fnLoadPngs=function(){if(root){root=document.getElementById(root);}else{root=document;} for(var i=root.all.length-1,obj=null;(obj=root.all[i]);i--){if(obj.currentStyle.backgroundImage.match(/\.png/i)!==null){bg_fnFixPng(obj);} if(obj.tagName=='IMG'&&obj.src.match(/\.png$/i)!==null){el_fnFixPng(obj);} if(applyPositioning&&(obj.tagName=='A'||obj.tagName=='INPUT')&&obj.style.position===''){obj.style.position='relative';}}};var bg_fnFixPng=function(obj){var mode='scale';var bg=obj.currentStyle.backgroundImage;var src=bg.substring(5,bg.length-2);if(obj.currentStyle.backgroundRepeat=='no-repeat'){mode='crop';} obj.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+src+"', sizingMethod='"+mode+"')";obj.style.backgroundImage='url('+shim+')';};var el_fnFixPng=function(img){var src=img.src;img.style.width=img.width+"px";img.style.height=img.height+"px";img.style.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+src+"', sizingMethod='scale')";img.src=shim;};var addLoadEvent=function(func){var oldonload=window.onload;if(typeof window.onload!='function'){window.onload=func;}else{window.onload=function(){if(oldonload){oldonload();} func();};}};return{init:function(){addLoadEvent(fnLoadPngs);},limitTo:function(el){root=el;},run:function(){fnLoadPngs();}};}();supersleight.init();
    see here
    My Site
  1. Is there an Under Construction/Repair flag?
    By Keltin in forum Templates, Stylesheets, Page Layout
    Last Post: 12 Oct 2009, 10:21 PM
  2. Under Construction - Mail
    By herbsorion in forum Templates, Stylesheets, Page Layout
    Last Post: 22 Apr 2009, 03:10 PM
  3. Is it possible to make an Under Construction page?
    By sheila123 in forum Templates, Stylesheets, Page Layout
    Last Post: 4 Mar 2009, 03:23 AM
  4. Under construction - development methodology
    By kohudson in forum General Questions
    Last Post: 31 Jan 2007, 08:41 PM
