Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 48
  1. #21
    Aug 2010
    Hartland, MI
    Default Re: Automatically populate category images from their product images
    Ok took store off "Down for Maintenance" and re implemented the changed category_row.php file.
    Check it out - here
  2. #22
    May 2004
    UK
    I keep getting sent back to home page not into category?
  3. #23
    Aug 2010
    Hartland, MI
    Quote Originally Posted by SarahL View Post
    Yup - the question is why?
  4. #24
    Aug 2010
    Hartland, MI
    Well I have to take the store back down for the weekend, hopefully we can figure it on monday...
  5. #25
    I'm just getting started with zencart. This was exactly what I was looking for with the random category pictures. However, it shows up the image unavailable picture for all. In the code, it should kick it to the transpixelgif if no file exists. I'm confused. You can check it out here: www.cheaperbyfar.com.
    Will
  6. #26
    Aug 2010
    Hartland, MI
    I ended up giving up (kept looping me back to the index page) and making all of my category photos using multiple photos of products for that category, came out very nice, but time consuming.
  7. #27
    Jul 2010
    Kent UK
    This is my Category row.php - works for me although i am not using category images on home page or seo urls.
    Infact i am using the css categories menu so dont even need this anymore.....
    * index category_row.php
    * Prepares the content for displaying a category's sub-category listing in grid format.
    * Once the data is prepared, it calls the standard tpl_list_box_content template for display.
    * @package page
    * @version $Id: category_row.php 4084 2006-08-06 23:59:36Z drbyte $
    die('Illegal Access');
    $title = '';
    $num_categories = $categories->RecordCount();
    $row = 0;
    $col = 0;
    $list_box_contents = '';
    if ($num_categories > 0) {
    if ($num_categories < MAX_DISPLAY_CATEGORIES_PER_ROW || MAX_DISPLAY_CATEGORIES_PER_ROW == 0) {
    $col_width = floor(100/$num_categories);
    $col_width = floor(100/MAX_DISPLAY_CATEGORIES_PER_ROW);
    while (!$categories->EOF) {
    global $db;
    $sql = "select products_image from " . TABLE_PRODUCTS . " where master_categories_id = " . $categories->fields['categories_id'] . " AND products_image IS NOT NULL AND products_image != '.jpg' AND products_image != '' ORDER BY RAND() LIMIT 1";
    $result = $db->Execute($sql);
    $cat_image = $result->fields['products_image'];
    $filename = DIR_WS_IMAGES . $cat_image;
    if (file_exists($filename)) {
    $cat_image = "pixel_trans.gif";
    if (!$categories->fields['categories_image']) !$categories->fields['categories_image'] = $cat_image;
    $cPath_new = zen_get_path($categories->fields['categories_id']);
    // strip out 0_ from top level cats
    $cPath_new = str_replace('=0_', '=', $cPath_new);
    // $categories->fields['products_name'] = zen_get_products_name($categories->fields['products_id']);
    $list_box_contents[$row][$col] = array('params' => 'class="categoryListBoxContents"' . ' ' . 'style="width:' . $col_width . '%;"',
    'text' => '<a href="' . zen_href_link(FILENAME_DEFAULT, $cPath_new) . '">' . zen_image(DIR_WS_IMAGES . $categories->fields['categories_image'], $categories->fields['categories_name'], SUBCATEGORY_IMAGE_WIDTH, SUBCATEGORY_IMAGE_HEIGHT) . '<br />' . $categories->fields['categories_name'] . '</a>');
    $col ++;
    if ($col > (MAX_DISPLAY_CATEGORIES_PER_ROW -1)) {
    $col = 0;
    $row ++;
    $categories->MoveNext();
  8. #28
    Aug 2010
    Hartland, MI
    WebMC-
    Thank you for reposting the code, I don't need it now thou...
    check out the images I ended up making here
    I'll have the store up till 5pm EST as I'm working on it.
  9. #29
    Jul 2010
    Kent UK
    good stuff good luck with the store - nice website name btw!
  10. #30
    Dunno, copied yours in exactly, still doesn't work. Guess I'm gonna go the other route.....come back to this later. The other addon I have installed is category dressing, but don't think that's interfering.
  1. Category images from product images
    By korayp in forum All Other Contributions/Addons
    Last Post: 22 Dec 2009, 04:12 PM
  2. How do I keep the banner images from resizing automatically?
    By bparker in forum Templates, Stylesheets, Page Layout
    Last Post: 19 Nov 2008, 03:33 AM
  3. Populate Images by Category and Product
    By borillion_star in forum Customization from the Admin
    Last Post: 1 Sep 2008, 08:57 PM
  4. Automatically populate sub category images + change attribute ordering
    By GTrotter in forum Templates, Stylesheets, Page Layout
    Last Post: 30 Apr 2007, 07:54 AM
