its mean i am handling INFORMATION as attributes? if yes, then every thing i should add manually in each product?It's not something that will exist separately as options or fields to define; you will have to enter the product's info in the HTML.
pleas explain this..You have created the information as attributes (and Model in the product details list); these will not go into a description table.
