I have just installed the software successfully but it is now asking me to change the filename (admin) I have followed the instructions but it still will not give me access can somebody help me.
You can change the folder name using a few different programs. I assume you have ftp access. Just rename that admin directory to something totally obscure. Then edit the configuration.php file in the newadminname/includes/ directory. You should be good to go.
Paul
For some reason nothing is working I do this:-
change admin filenames to something else
Then update configure.php in .../admin/includes/configure.php then change:-
andPHP Code:
define('DIR_WS_ADMIN', '/admin/');
define('DIR_WS_HTTPS_ADMIN', '/admin/');
am I right if so this does not work from me anybody got any ideas to get this working today.PHP Code:
define('DIR_FS_ADMIN', '/home/elececou/domains/electronicenterprise.co.uk/public_html/admin/');
define('DIR_FS_CATALOG', '/home/elececou/domains/electronicenterprise.co.uk/public_html/');
Silly old me if anybody else has had this problem make sure you read this:-
D - What if it doesn't work?
If it doesn't work, then you've missed one or more of the steps. THE MOST COMMON MISTAKE is ignoring the read-only vs writable alert in BRIGHT RED TEXT in step A.
now working.
