samar777
1. You MUST have SSL enabled on your site. If you are asking this question, that means that you dont have SSL yet.
Apply for an SSL from your hosting company first. It will probably take a couple of days for you to get SSL certificate.
2. After you get SSL, you can activate it. ( search for "activate SSL" in the forums"
3. Re: activating paypal payments pro.
Its very easy. everything is already there for you in zen cart. just a matter of few clicks.
admin>modules>payments>payments pro>install. fill in the blanks and you are set.
4. yes, customers stay on your website when using payments pro.
