Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    N of San Antonio TX
    Default Re: How to fix stylesheet errors? -PureGreen
    You need to go to the main page and click on "CLICK HERE - Recovering from Hacks."
    You have a frame on your login that is hijacking visitors and probably installing malware.
    Did you read the posting tips?!?
    Things We've Done
    MOD: Scheduled Events
    Do you have any suggestions on how to fix this?
    Determine the source
    If zenflavor or if form your possibly infected local pc
    The okd addage "garbage In - - garbage Out" holds here
    It is not in the sanctioned ZenCart distribution
    Get Your Business Found
    Mar 2011
    Thank You! I think I will delete it and go with an expensive shopping cart software program versus using an open-source application.
    Make sure your server (and your pc) is completely clean before you do, or the hacker may have access to that expensive system just as it did with Zen Cart when you installed it. Being a paid "expensive" system does not necessarily give immunity from all hacks.
  1. Replies: 14
    Last Post: 20 Oct 2010, 10:43 PM
  2. PureGreen Template
    By kmol in forum Addon Templates
    Last Post: 30 Mar 2009, 02:35 PM
  3. category dressing errors and move add to cart errors
    By MachaNeko in forum Templates, Stylesheets, Page Layout
    Last Post: 18 May 2008, 02:29 PM
  4. Admin errors on fresh installation - module errors and language definition errors
    By etrader in forum Installing on a Linux/Unix Server
    Last Post: 5 Oct 2007, 09:05 AM
