Page 9 of 14 FirstFirst ... 7891011 ... LastLast
Results 81 to 90 of 137
  1. #81
    Aug 2004
    Belfast, Northern Ireland
    Default Re: Ceon Manual Card Payment Module v3.0.0
    Quote Originally Posted by christymreed View Post
    Just a suggestion and not a criticism of the sheer genius of the Ceon module I am very pleased with it.
    As suggested above then, change the setting "Credit Card Number" in "Minimum Values" in the Zen Cart Configuration menu.
    I'll probably change the main code to use this value as well then.. the JavaScript checking code already does, so your setting must be below 16.
    There may be places where 12 digits is fine so I won't be enforcing any arbitrary limits, just keeping the LUHN check as it is, that'll do for validation.
    Hope that helps!
    All the best..
    Conor
    ceon
  2. #82
    May 2009
    Ah! I see! There is a place in the Admin at Configuration -> Minimum Values to set the minimum length of the credit card. Mine was set to 10 which would obviously allow a 12 digit credit card number. Since I do accept American Express and those can be 15 digits, I changed the number to 15. I take VISA, MS, AMEX, and Discover. AMEX cards would have the least digits with 15. So voila! 12 digit issue solved! (I hope ;)
    Christy
  3. #83
    May 2010
    "Why would you bother really? You'll have seen the card number come through like that and you obviously won't ship the order if the card can't be charged?"
    A couple of points:
    1. To not have to contact the customer by email or phone to get their correct card number.
    2. To get the sale. Or we could just say "Wrong card number. Won't clear. So forget about the sale guys. We don't want their money that bad".
    This is a critical part of the efficiency of the module.
  4. #84
    May 2010
    Also, I should note that when contacting the customers about this, they have said they did enter 16 digits. Hmmmm.
  5. #85
    Aug 2004
    Quote Originally Posted by elninomago View Post
    Then you'll have received all 16.
    As I've said here before.. e-businesses are advised use a payment gateway and not a manual card module.
    You should consider that if you don't want to miss out on further sales.
    All the best.,,
    Conor
    ceon
  6. #86
    Feb 2007
    Ontario, Canada
    Wow, that upgrade went absolutely flawlessly! That never happens!
    Thank you for the clear instructions and for the module itself.
    Thanks, Colleen
    www.actionformsinc.com
    To err is human, but to really foul things up requires a computer. Farmers' Almanac, 1978
  7. #87
    May 2007
    Southern California
    The module is not sending out email notifications. Which is a big problems since we need the middle digits of the credit car. It was working once, but not working now.
    Please advise.
  8. #88
    May 2007
    Southern California
    Conor,
    For some reason the email notifications have stopped.
    Not sure what happened. I checked my email junk folder, spam folder, and so far, we did not receive any emails that was entered into the admin control of the site.
    We even re-uploaded the original files.
    Without the emails we cannot get the middle credit card numbers to charge the client.
    please help.
    Jim
  9. #89
    Australia
    Hi Coner,
    I have this and the surcharge module installed. Both working.
    I moved my store to a different server after testing and now the images in the payment module admin config page are pointing at the old locations. I'm not sure where to go to fix this minor problem.... I can't seem to finf the file that specifies the path to these images.
    Cheers all,
    Gruntre69
    WayCool
    Zen is Way Cool too!
  10. #90
    Apr 2012
    Conor - Just curious to know if you guys have any plans of upgrading to support ZC 1.5.x ?
  1. Ceon Manual Card Payment Module v2.0.0!
    By conor in forum Addon Payment Modules
    Last Post: 5 Sep 2011, 08:55 AM
  2. Ceon manual card module - cc error leads to page not found
    By jenniesummitreks in forum Addon Payment Modules
    Last Post: 16 Sep 2009, 09:28 PM
  3. Deleting all credit card info in admin - Ceon Manual Card
    By MaureenT in forum Addon Payment Modules
    Last Post: 16 Mar 2009, 07:22 PM
  4. Ceon Manual/Offline Card Payment Module v1.0.0!
    Last Post: 27 Feb 2009, 10:04 PM
  5. Re: Ceon Manual/Offline Card Payment Module v1.0.0!
    By wizarddave in forum Addon Payment Modules
    Last Post: 2 Jan 2008, 05:13 PM
