Results 1 to 7 of 7
    Dec 2009
    Default MSRP Addon Problem?
    Has anyone had a problem with the MSRP addon? http://www.zen-cart.com/index.php?ma...oducts_id=1140
    I just installed per the instructions, and now my product details page doesn't show up... I just get a white screen with nothing. I have triple checked the files and everything was adjusted correctly. The only think I noticed was that the instructions call for alterations of the "admin/modules/update_product.php" & "admin/modules/product/collect_info.php" files, but there isn't any "modules" file under admin unless you go into admin/includes/modules/etc.
    Any input would be appreciated. I am afraid my shopping cart won't function properly.
    Apr 2004
    UK
    Default Re: MSRP Addon Problem?
    Forum thread for that particular mod at
    http://www.zen-cart.com/forum/showthread.php?t=54857
    check your error log in the root of your zc install (the same level with admin and includes directories). The white screen is from an error breaking the page. The error log will tell you exactly where it was broken.
    Zen Cart and it's community are the best!!
    Dec 2009
    Quote Originally Posted by lankeeyankee View Post
    I am not seeing this "error log" where can I find it? Also, is this mod known for causing problems?
    It should be in the root of your site, if your install is in /cart then the file is in /cart. Scroll down past all of the directories like the admin and includes to where the individual files are and you should see the error log file.
    This mod requires, like so many zen cart mods, changes to core files. It's easy to make a mistake! This one is no different than any other ones although the modification to includes/functions/function_prices.php can be a little tricky.
    7
    Dec 2009
    I fixed the issue and now everything seems to be working. I think I just copied some of the code wrong in the manual install. So I ended up copying the files directly over and SUCCESS!!
  1. v151 Problem installing MSRP display
    By SilverHD in forum All Other Contributions/Addons
    Last Post: 17 Oct 2017, 04:06 AM
  2. v150 Help with addon MSRP: Add a new field to the products table
    By Johnnycopilot in forum All Other Contributions/Addons
    Last Post: 5 Jan 2014, 11:28 PM
  3. v139h msrp/discount addon?
    By ediscs in forum All Other Contributions/Addons
    Last Post: 27 Feb 2012, 05:00 PM
  4. Problem integrating additional image titles addon and commercial addon
    By strugglingnovice in forum All Other Contributions/Addons
    Last Post: 15 Aug 2010, 03:07 PM
  5. MSRP Color Problem Solved
    By Little Red Crane in forum All Other Contributions/Addons
    Last Post: 10 May 2010, 08:07 PM
