Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
    Apr 2012
    Florida, USA
    Default Re: CKEditor problems
    Problem solved, found the correct place to download for ZEN http://www.zen-cart.com/downloads.php?do=file&id=1098
    thanks,
    Lou
    Jun 2006
    Sea Lake, Australia
    Version 3.7 of ckeditor, in the file admin/includes/ckeditor.php has the following line
    <script type="text/javascript" src="<?php echo (strstr('ttps:', HTTP_SERVER) ? 'https' : 'http'); ?>://www.google.com/jsapi"></script>
    is ttps correct?
    3
    Are you asking because it's not working for you?
    Jun 2006
    Sea Lake, Australia
    It works (but so did the previous version), but in ie9, it seems to think that there are insecure items. Don't get that in other browsers.
    3
    The change was made specifically to prevent the messages about insecure items which were occurring in earlier integrations.
    As for it saying 'ttps' that was deliberate, since some string searches fail when the variable being searched/matched starts as the first character. Hence the intentional omission of the 'h'.
    Jun 2006
    Sea Lake, Australia
    OK, thanks for the reply DrByte.
  7. #17
    May 2012
    Need help folks.
    I downloaded this and installed it on my local server (XAMPP) and it works fine. Im able to use CKeditor as the default html editor.
    Once it is on my remote server (godaddy) it does not work. It shows CKeditor on the dropdown, but when i select it, the screen refreshes and im back to the text only editor.
  8. #18
    Dec 2011
    Houston, Texas, USA
    I have my own "CKeditor not working" issue, and it looks like the suggestion here has solved my problem, at least for the moment: http://www.zen-cart.com/showthread.p...or-not-working
    I'm using 1.3.9h, in case that matters.
  9. #19
    May 2012
    Default Re: Problem getting ck editor to work properly in zc1.5
    Quote Originally Posted by Icecube View Post
    Hi all,
    Ok so like many I am having issues with CKeditor. I installed it as per instructions (so I think) I am using Zen V1.5 and the latest version of CKE. I have no problem setting the default HTML editor to EDITOR_CKEDITOR (that is what shows up on mine).
    My problem is that when I go to something like "DEFINE PAGES EDITOR FOR : ENGLISH" I am able to choose the ckeditor in the list, but as soon as I do it just automatically chooses the Plain Text editor.
    I guess it's not "catching" something, but I really don't know what.
    Someone please help
    I had this same exact problem, (how I found this thread)
    As usual I had transfered each file individually because I usually end up customizing a fair amount of files and I find that making a little extra effort at the start can save me headaches later down the line, like accidentally overwriting a previously modified file. But anyway, I had left out the ckeditor.php in the admin/includes/ folder. I am not sure if the original poster figured out his problem, but would suggest that if anyone else has this problem, to carefully double check that ALL the mod files are copied onto your server, and that they were not corrupted during transfer.
  1. CKEDITOR is not there in 150
    By stefanl in forum Basic Configuration
    Last Post: 7 Jan 2012, 03:25 PM
  2. Should I install CKeditor 3.2.1a , or CKeditor 3.4 From CKeditor.com
    By AlanL in forum All Other Contributions/Addons
    Last Post: 24 Aug 2010, 12:33 PM
  3. CKEditor install
    By JILK in forum All Other Contributions/Addons
    Last Post: 15 Jun 2010, 12:45 AM
