Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 62
    Sep 2005
    Waikato, New Zealand
    Default Re: Updating Mod for 150 - Little Problem
    You should see it working here
    grumpykiwi.com/
    once you have browsed a few products obviously (embarrasingly i forgot to do that originally)
    Webzings Design
    The last couple of Zen-Cart sites we have worked on, Darncat Designs, Nags to Riches, Magic Brow Bands.
    Great, will give that a try in just a moment and get back to you :)
    Ok it failed miserably on my second test shop
    SO
    Try this, it works for me
    zen_image(DIR_WS_IMAGES $recent_products->fields['products_image'], SMALL_IMAGE_WIDTHSMALL_IMAGE_HEIGHT
    becomes
    zen_image(DIR_WS_IMAGES $recent_products->fields['products_image'], $recent_products->fields['products_name'],SMALL_IMAGE_WIDTHSMALL_IMAGE_HEIGHT
    The solution in my first post regarding a null field also works, but this one is reader friendly by filling the alt and title tags
    Nigel
    Webzings Design
    The last couple of Zen-Cart sites we have worked on, Darncat Designs, Sweet Brucies
    Go that extra mile, you never know what's at the end of the road
    Empowerment Sanctuary
    Ok...here's where we're at....
    Recently Viewed SIDEBOX mod works perfectly in ZC150
    Recently Viewed ITEMS also works in ZC150, insofar as the sidebox is concerned...and that is thanks to the change in code that you posted.
    However, the difference in functionality between these two mods is that the Recently Viewed ITEMS mod is supposed to add a centerbox so that users can have recently viewed items in a centerbox beneath the "also purchased" centerbox. That's what the optional file is for.
    That functionality is not working, so at this point, the two mods are essentially the same.
    I'm going to go ahead and submit the Recently Viewed SIDEBOX mod to the downloads section (after I write a readme for it).
    If I can get the Recently Viewed ITEMS mod to display the centerbox, then I will submit that one too...so folks will have a choice between showing their additional items in a sidebox, a centerbox, or both.
    Thanks so much for your help!!
    Sep 2005
    Do you know there is a spelling mistake in the optional files?
    the final folder is named template rather than templates
    3. Optional Install File\includes\templates\YOUR_CUSTOM_TEMPLATE\template
    i am fairly sure it should be templates
    Webzings Design
    Quote Originally Posted by nigelt74 View Post
    You're right...I was in the process of adding/naming that directory when my grandson climbed in to my lap so the "S" never got added. Thanks for catching it!
    Sep 2005
    hmmm
    just noticed in your error message
    includes/modules/FILENAME_RECENT_PRODUCTS_MODULE.php
    Thats not the name of a file is it, doesn't that mean a define or something is incorrect?
    Webzings Design
  7. #17
    hmmm
    Wow, that's really obvious...can't believe I missed it! Thanks! I made the correction to the file and will test tomorrow and post results back here.
    Thanks again for all your help!
  8. #18
    Changed includes/modules/FILENAME_RECENT_PRODUCTS_MODULE.php
    includes/modules/FILENAME_RECENT_PRODUCTS.php
    Changed line 12 of /includes/templates/atestcustom/templates/tpl_modules_recent_products.php from
    include(DIR_WS_MODULES zen_get_module_directory(FILENAME_RECENT_PRODUCTS_MODULE));
    include(DIR_WS_MODULES zen_get_module_directory(FILENAME_RECENT_PRODUCTS));
    Same result:
    • Centerbox won't display
    • Same error being thrown
    • Sidebox displays as expected
  9. #19
    If either FILENAME_RECENT_PRODUCTS_MODULE or FILENAME_RECENT_PRODUCTS is defined somewhere, the uppercase will be replaced by its defined value when used... so it appears you are missing a define.
  10. #20
    Ok...here's where I get lost because I'm not a coder.....but shouldn't defines be in the language file? Or can they be anywhere? Perhaps the missing define should be on line 12 of the file mentioned in the error?
    And..how do I go about writing a define statement? Can I just google that?
  1. CSS updating problem!
    By Magik in forum Basic Configuration
    Last Post: 11 Jan 2010, 03:24 AM
  2. Downloads Updating Problem
    By Rasyr in forum Bug Reports
    Last Post: 18 Jan 2008, 07:12 PM
  3. problem with updating status
    By snarkys in forum Built-in Shipping and Payment Modules
    Last Post: 13 Jan 2007, 02:50 AM
