Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 62
  1. #21
    Default Re: Updating Mod for 150 - Little Problem
    Ok, I found a tutorial at w3schools.com on how to write a PHP define.
    The sample they provided looks simple enough:
    define("GREETING","Hello you! How are you today?");
    echo constant("GREETING");
    But here are my questions:
    1. Where do I put the define?
    2. How do I determine what the define's value should be?
    I think that in order to understand what the define's value should be, I need to understand the logic behind the output (i.e. where will it appear so I can figure out what its supposed to say? what purpose is it serving?)
    Go that extra mile, you never know what's at the end of the road
    Empowerment Sanctuary
  2. #22
    A question about learning to interpret error messages:
    How can I tell that the error message below is telling me that I'm missing a define? Is there something specific in there that points me in that direction, or does it just come with time and learning?
    [31-Mar-2012 22:09:27]
    PHP Warning:  include(includes/modules/FILENAME_RECENT_PRODUCTS_MODULE.php) [<a
    href='function.include'>function.include</a>]: failed to open stream: No such file or directory in
    /***/***/public_html/***/includes/templates/atestcustom/templates/tpl_modules_recent_products.php
    on line 12
    PHP Warning:  include() [<a href='function.include'>function.include</a>]: Failed opening
    'includes/modules/FILENAME_RECENT_PRODUCTS_MODULE.php' for inclusion
    (include_path='.:/usr/lib/php:/usr/local/lib/php') in
    /***/***/public_html/***/includes/templates/atestcustom/templates/tpl_modules_recent_products.php on line 12
    Note that I've already made the following changes, yet the error remains the same:
    Changed includes/modules/FILENAME_RECENT_PRODUCTS_MODULE.php
    includes/modules/FILENAME_RECENT_PRODUCTS.php
    and
    Changed line 12 of /includes/templates/atestcustom/templates/tpl_modules_recent_products.php from
    include(DIR_WS_MODULES zen_get_module_directory(FILENAME_RECENT_PRODUCTS_MODULE));
    include(DIR_WS_MODULES zen_get_module_directory(FILENAME_RECENT_PRODUCTS));
  3. #23
    They usually go in a separate file.. Depending on the how it's being used in Zen Cart they could be in a language folder, a class folder, a functions folder, an extra datafiles folder or even an extra configures folder in Zen Cart.
    Do a search through your store using the developers toolkit (search for "define(") to look for existing examples to see how you would construct one.
    For Edit Orders there is one similar to what you are trying to do. From line 21 of admin/includes/extra_configures/edit_orders.php
    define('FILENAME_ORDER_EDIT', 'edit_orders.php');
    Super Orders also uses a similar file to point links to the orders.php file
    Quote Originally Posted by ScriptJunkie View Post
    My Site
  4. #24
    *****Warning: Post typed as I wandered through my thought process. Please bear with me*****
    Ohhhh I see....the define you listed below tells the code which file to look in. I think I get it now!
    define('FILENAME_ORDER_EDIT''edit_orders.php');
    So, I would write it this way:
    define('FILENAME_RECENT_PRODUCTS''recent_products.php');
    But, as you said...there are several folders I could place such a file in (or several files I could add the define to). How do I determine how the define is being used in Zen Cart in order to determine where to place it?
    Since this mod has no class folder, no functions folder, no extra datafiles folder or an extra configures folder....How do I determine which of those is the best one to create for the new defines file?
    :::thinking:::: the file that calls this define is the one referenced in the error log: includes/templates/custom_template/templates/tpl_modules_recent_products.php. The code from that file which actually calls the define (if I understand all this correctly), is:
    So....I'm guessing here....the above include is telling zen cart what the name of the module is? And the define statement is telling zen cart which file some of that mod's code is in?
    Is that right? If so, I would think that adding the define statement to the language file would be appropriate?
    Doing so would change language/english/extra_definitions/recent_products.php file from:
    // recently viewed sidebox title name
    define('BOX_HEADING_RECENTLY_VIEWED''Recently Viewed');
    // define file name
    Is that right?
    Quote Originally Posted by DivaVocals View Post
  5. #25
    I can't say that what you posted WON'T work, but it's not the way I would do it..
    I wouldn't put it in a language file because it's not a constant that is used to display text on screen anywhere (which is the purpose of the language files). If the constant being called is not part of a class or a function, then that's not where you'd put it either..
    Eliminating all of these, the extra_datafiles is probably the place I'D put it as it's not a constant related to a configuration item I wouldn't use the extra_configures folder, but you'd be better off waiting for someone more knowledgeable than I to confirm this. (BTW, the word "extra" in the folder name is a HINT that these are extra files usually related to a something that expands current functionality. (Again, someone can correct me on that too, it's how I always interpreted these folder names)
    // define file name
    Is that right?
    My Site
  6. #26
    ahhhhh ok. I'll give that a shot and see if it works.
    If not, I'll report back here and see what suggestions others might have.
    And...as I've just realized that I completely forgot about final IH testing (SO SORRY), I'm going to go do that right now.
  7. #27
    Sep 2005
    Waikato, New Zealand
    Should add there is a syntax error somewhere in
    /includes/modules/recent_products.php
    or at least thats what dreamweavers syntax checker tells me
    apparently its the very last line, which tends to mean there is an errant brace or something somewhere above
    I also get the above error id I add an extra datafile with this in it
    define('FILENAME_RECENT_PRODUCTS_MODULE', 'recent_products.php');
    I note you aren't using the MODULE bit, if i don't use that i just get the old error you mentioned
    Nigel
    Webzings Design
    The last couple of Zen-Cart sites we have worked on, Darncat Designs, Sweet Brucies
  8. #28
    Not that I'm an expert on the filesystem either, but that makes the most sense to me. It would be "easier" to put all the defines in one (language) file for this small mod, but that wouldn't really be treating the different defines properly.
  9. #29
    Sep 2005
    bah humbug
    has
    14 {
    11 }
    no wonder there are syntax errors!!!
    Nigel
    Webzings Design
  10. #30
    Sep 2005
    Ok I think i may have it working, well sort of. I am still not sure I have added the braces in the correct places
    and it is saying "featured products" rather than "recently viewed"
    go here and have a look at various products and the recently viewed should appear both below and in the sidebox
    http://grumpykiwi.com/
    Nigel
    Webzings Design
  1. CSS updating problem!
    By Magik in forum Basic Configuration
    Last Post: 11 Jan 2010, 03:24 AM
  2. Downloads Updating Problem
    By Rasyr in forum Bug Reports
    Last Post: 18 Jan 2008, 07:12 PM
  3. problem with updating status
    By snarkys in forum Built-in Shipping and Payment Modules
    Last Post: 13 Jan 2007, 02:50 AM
