Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 62
  1. #41
    Default Re: Updating Mod for 150 - Little Problem
    Quote Originally Posted by DivaVocals View Post
    Thank nigel and Glenn.. I'm just the backup singer in this group.. Just call me one of the Pips!!
    **on the midnight train to Georgia - whoo hoo**
    LOL sing it girl!
    Go that extra mile, you never know what's at the end of the road
    Empowerment Sanctuary
  2. #42
    Quote Originally Posted by ScriptJunkie View Post
    LOL sing it girl!
    My Site
  3. #43
    Ok, this worked fine on my test site, but installing it into a 150 live store gives me this error:
    PHP Parse error: syntax error, unexpected '}' in includes/modules/recent_products.php on line 20
    Suggestions?
  4. #44
    Suggestions?
    Compare the includes/modules/recent_products.php files in your test and live store.. is the line where you get the error in your live store different?? and I don't use the line number as it's line 20 in the live store.. that same line might be a different line number in the test store..
    My Site
  5. #45
    Unable to compare. I uninstalled the mod from my test store once testing was completed.
    During the initial install on the live store, filezilla kept timing out and disconnecting. So this morning, I did a complete uninstall, reinstall of the mod in case any files were corrupted the first time around.
    Same results. The code in includes/modules/recent_products.php, lines 17-21 is below. I don't know a lot about php code...but I don't see what's wrong with it.
    if (RECENT_VIEWED_PRODUCTS_MAXIMUM < 1)
    	//set the maximum number of recently viewed products here
    	 $maximum_recent = 5;
    	 $maximum_recent = RECENT_VIEWED_PRODUCTS_MAXIMUM;
  6. #46
    You're missing the { that should follow the if test:
    if (RECENT_VIEWED_PRODUCTS_MAXIMUM 1) {
    $maximum_recent 5;
         } else {
    $maximum_recent RECENT_VIEWED_PRODUCTS_MAXIMUM
  7. #47
    $maximum_recent 5;
         } else {
    Ahhhhhhhhhhhhhhh.. this totally explains the error.. since the error says that a closing bracket was found when there was no opening one..
    Scriptjunkie, if you have a program like Developer's Notepad, it might have been able to help you spot this since it colors the code, and you can usually spot invalid stuff (like missing opening brackets..) because it would be colored differently.. Hard to explain this really.. If you use this program you will see what I mean.. Great for novices like myself to troubleshoot stuff with.
    My Site
  8. #48
    $maximum_recent 5;
         } else {
    Thanks Glenn! I'll get that fixed and upload a corrected fileset to the downloads section.
  9. #49
    I use Notepad++ and it does indeed color the code....but I haven't been using it long enough to know what the color coding is telling me. LOL maybe I should read the help file <grin>
  10. #50
    Hmmm....ok...now I'm getting these errors:
    PHP Warning: require(includes/templates/template_default/templates/tpl_modules_recent_products.php) [<a href='function.require'>function.require</a>]: failed to open stream: No such file or directory in /includes/templates/custom/templates/tpl_product_info_display.php on line 302
    and
    PHP Fatal error: require() [<a href='function.require'>function.require</a>]: Failed opening required 'includes/templates/template_default/templates/tpl_modules_recent_products.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /includes/templates/custom/templates/tpl_product_info_display.php on line 302
    This is the code on line 302 of tpl_product_info_display.php:
    <!--bof recent products module-->
       <?php require($template->get_template_dir ('tpl_modules_recent_products.php',DIR_WS_TEMPLATE$current_page_base,'templates') . '/tpl_modules_recent_products.php'); ?>
       <!--eof recent products module-->
  1. CSS updating problem!
    By Magik in forum Basic Configuration
    Last Post: 11 Jan 2010, 03:24 AM
  2. Downloads Updating Problem
    By Rasyr in forum Bug Reports
    Last Post: 18 Jan 2008, 07:12 PM
  3. problem with updating status
    By snarkys in forum Built-in Shipping and Payment Modules
    Last Post: 13 Jan 2007, 02:50 AM
