copy from /includes/configure.php
?php
* @package Configuration Settings circa 1.5.0
* File Built by zc_install on 2012-04-25 07:15:58
define('HTTP_SERVER', 'http://localhost');
define('HTTPS_SERVER', 'https://kawaiiclothing.zapto.org');
define('DIR_WS_PHPBB', '/');
define('DIR_FS_CATALOG', 'C:/xampp/htdocs/');
define('DB_TYPE', 'mysql');
define('DB_PREFIX', 'zen_');
define('DB_CHARSET', 'utf8');
define('DB_SERVER_USERNAME', 'private');
define('DB_SERVER_PASSWORD', 'private');
define('DB_DATABASE', 'zencart');
define('DIR_FS_SQL_CACHE', 'C:/xampp/htdocs/cache');
// EOF
