Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Aug 2007
    Gijón, Asturias, Spain
    Default Re: localhost and website add problem
    Unless you intend to do some serious "offline" work, and wish to TEST your modifications, there is no real need to install on a LOCAL machine.
    To go off-topic somewhat, I would argue a local test server should be seen as absolutely essential to test ALL modifications thoroughly, however minor, before uploading to the live one. Additionally its far easier to search for code locally, do modification merges etc.
    Steve
    "Totally Zenned" my a*se!
  2. #22
    Jun 2005
    Hertfordshire, UK
    We have a dedicated DEV zone on a web server, remotely hosted, set up under all indentical conditions to our live hosting.
    Trouble with LOCAL (XAMPP) is that it does not precisely mirror a live webserver.
    Did my post help you fix something? You can show your gratitude by buying the the dev team coffee.
  3. #23
    Aug 2007
    Agreed. When I get an odd problem I use a real test webserver. Still, I think the useability of a local install as regards to finding stuff is a big advantage for both new users and semi-experienced users.
    Steve
  4. #24
    3
    Moderator comment: Let's try to stay on-topic. If you want to debate or praise the merits of a localhost setup, take it to a more appropriate place, instead of hijacking someone's request for help with a technical problem.
  1. problems copying over my website onto my localhost
    By davowave in forum Installing on a Windows Server
    Last Post: 19 Nov 2011, 07:01 AM
  2. Installing on localhost: DB problem
    By todoonada in forum Installing on a Linux/Unix Server
    Last Post: 5 Nov 2009, 08:48 AM
  3. Is this a localhost problem?
    By Canned_Heat in forum General Questions
    Last Post: 19 May 2007, 02:45 PM
