Results 1 to 5 of 5
    Jun 2009
    Default Fresh install ...need help with html editor problem
    Hey All,
    Fresh install, only in the very beginning of set up and I seem to have a problem already. Under configuration/mystore/ I am trying to change the HTML editor. The current value is set at "NONE". When I try to change the only option I get from the drop down menu is "Plain text". I would like to change to Rich text editor which is not currently an option. What did I do wrong? Thanks!
    Dec 2006
    Seligman, MO U.S.A.
    Default Re: Fresh install ...need help with html editor problem
    You didn't do anything wrong. The editors have been taken out of the Zen-Cart build..........due to security issues, I believe.......... Anyway, you'll have to install one. Just search the "Plug-ins" section for "editors" (no quotes)...........you'll find 'em. :)
    Hope this helps.
    Teach them to shop and they will shop today;
    Teach them to Zen and they will OWN a shop tomorrow!
    Feb 2005
    Lansing, Michigan USA
    This one is considered the best:
    http://www.zen-cart.com/downloads.php?do=file&id=1098
    Get Em Fast - is your 'dot' key stuck ?
    Dec 2006
    Seligman, MO U.S.A.
    Yea..........it happens sometimes. Just those little...............uh........thinking pauses, ya' know. You're right though.......I do get carried away with it sometimes, huh?
    Jun 2009
    Thanks guys!
  1. need help, use 1.3.8 db on 1.3.9 fresh install,
    By newguy00 in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 23 Jul 2011, 05:54 AM
  2. Please Help - Problem with HTML Editor (I think) in 1.3.7
    By gav_alexander in forum General Questions
    Last Post: 8 Jan 2009, 06:28 PM
  3. Had to do fresh install - need help!!
    By zingslings in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 12 Apr 2008, 04:38 PM
