I've just checked my test install at airsoftjack.com and it's working fine. Dunno whatsup with this instance.
The SSL FAQ article and the comments inside the admin configure.php file both explain that if you want your ENTIRE admin to be SSL-protected, simply set the HTTP_SERVER to an https URL, just like your HTTPS_SERVER value.
And, remember, the file is stored as read-only on the server, so you'll need to make the file writable before your changes can be saved to the file, else your changes won't take effect.
thanks DrByte,
Had a setting wrong in dreamweaver. Did it this morning by ftp and it worked! Thanks again.
