Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
    Aug 2007
    Gijón, Asturias, Spain
    Default Re: CEON advanced shipping module - questions
    Is there a way to make Advanced Shipper aware of Better Together?
    ...anything is always possible...it's the time/cost of the path to get there...
    Some generic advice...
    I would see if this discount scheme works with the standard Zen Cart shipping methods first on a clean installation to check the issue is not with Better Together.
    Then figure out what variables are beng used to carry this data (Superglobals) and see where/if Advanced Shipper is not dealing with them the same way.
    Steve
    github.com/torvista: Spanish Language Pack, Google reCaptcha, Structured Data, Multiple Copy-Move-Delete, Image Checker, BackupMySQL Admin/Auto...
    Aug 2012
    Anyway for advanced shipper box not to show on delivery information page when no advanced shipping methods are available?
    May 2007
    Wondering if anyone has enough experience with this module they might know the answer to my configuration need. My assumption is that I can use the nested table of rates to effect my solution but not sure how to make it work.
    The scenario is I have 2 categories. One category uses usps (Cat A). The other category uses ups (Cat B) I have that configured fine.
    But if a customer orders from both categories I want it to use UPS only. Therein is the problem because obviously it will still divided the shipping amongst the 2 categories/items.
    The good news is Cat A has weights of 20lbs and over and price of $100 and over and Cat A has low weights and prices. So my assumption is that using nested table of rates in the Cat A "Method" there might be a way to tell the mod that if the total order price or total order weight is over a certain amount it will default to UPS only but not sure how to do that. Anyone with knowledge on this mod have any suggestions?
    So the basic idea is:
    Only Cat A - USPS
    Only Cat B - UPS
    Mixed Cat A and Cat B - UPS
    is this correct?
    Aug 2009
    Longs, SC
    Try this but change the weight breakpoints. The way this is set up is if the total weight is 1lb or less it will use the usps rate calculator. If it's over it will use fedex. You need to configure both shippers in the region definition.
    <weight>1:usps, *:ups</weight>
    Jan 2013
    i have modified ceons module to only show when when certain products in cart.
    Ex.
    only show this when cat a in cart
    only show this when cat b in cart
    or only show this when cat a and b in cart
    my modifications are only applied to v5.02 and is in this forum
  7. #17
    May 2007
    Quote Originally Posted by badarac View Post
    To Ajeh's question, answer yes. But in respect to configuration I was able to find a solution myself with further exploration. That said, badarac's solution would probably solve it as well. The method I am using is based on price because in my instance all Cat A pricing below a threshold would go by regular mail anyways and above a threshold by UPS whereas all Cat B pricing is above $100 and Cat B always has to go by UPS. So if someone orders something from category A and then something from category B with this formula it will always show UPS. so I used a formula like this in the table of rates:
    <totalorderprice>0-99:usps, 100-9999:ups</totalorderprice> eazy, peazy. Appreciate the attention and suggestions!
  8. #18
    Aug 2007
    A shipping problem I have is that certain large (but light) items get charged steep volumetric rates by my courier so I need that to be reflected in the shipping price.
    In my testing, having a separate method for these large items has the effect of offering the volumetric method and the normal method when the cart has mixed items, so I trying the idea of adding another surcharge/rates option to the normal method based on products id ie<pid>1234:20, 1235:20</pid>
    While I have almost got it working, just wondering if anyone else has done anything to solve a similar problem?
    Steve
  1. v151 Ceon Advanced Shipper - how can I limit the display of available shipping methods?
    By dysfunctional in forum Addon Shipping Modules
    Last Post: 31 Jan 2015, 04:03 AM
  2. v151 Ceon Advanced Shipper v5.02 Updated to include freightquote.com shipping
    By jimmie in forum Addon Shipping Modules
    Last Post: 18 Dec 2014, 01:48 PM
  3. v150 Ceon shipping module: remove shipping options for certain product combinations?
    By irish_1985 in forum Addon Shipping Modules
    Last Post: 28 Oct 2012, 02:18 AM
  4. Ceon Advanced Shipper
    By Danielle in forum Addon Shipping Modules
    Last Post: 20 Jul 2010, 05:03 PM
  5. Ceon Region Tables Shipping Module 1.0.0 Beta 1!
    By conor in forum Addon Shipping Modules
    Last Post: 6 Mar 2008, 10:42 AM
