lhungil
I see calls to @imagecreatetruecolor, @imagecreate, and @imagecopyresampled in IH4. The @ will suppress error message including any PHP "Out of Memory" errors. I'm going to "guess" this is the issue, as those functions usually create an uncompressed image (which could be quite large at higher resolutions).
If after removing the "@" from those calls you see PHP "Out of Memory" errors, you may want to check what is configured in IH4 for max dimensions on the generated "large" images.
