Results 1 to 5 of 5
    Feb 2014
    Default Module function problem (responsive_sheffield_blue)
    I go to the admin page “Module” , click the “Ceon URI Mapping (SEO) Config” is no problem, page came to the “Ceon URI Mapping (SEO) Config” page.
    but no matter I click the “Payment” “Shipping” and “Order Total” , the pages came empty and shows “Flexible Footer Menu” .
    I don’t understand. What's wrong with it ?
    see the attached photos.
    the problem is as same as my other post . when I clicked the “edit” button to revise the product . The page came empty too.
ID:	16434   Click image for larger version.
    Default Re: Module function problem (responsive_sheffield_blue)
    As suggested in your above post, it appears that these two things are in one way or another related.
    There certainly is information missing in both posts/threads such as ZC version, php version, and other detail requested from the posting tips. Posting tips are presented above the message box of every new message generated.
    Please see the information from your other post in: https://www.zen-cart.com/showthread....heffield_blue)
    Feb 2014
    So How could I amend this problem ?
    Quote Originally Posted by cmike View Post
    First, pick a thread in which to post (suggest the other thread), and then post the information identified above as missing. Otherwise, to resolve the problem either investigate into all of the data that the ZC software provides when an error occurs; compare the software currently running against a clean install; understand what each change is, whether such changes are properly made; correct the most recently documented error; repeat, as necessary, the applicable steps above until errors no longer occur, or seek someone to do all that for you. But it comes down to if you are seeking outside assistance, provide information (that doesn't jeopardize security) so that others can help figure out what is going on and how/why it happened.
    7
    Agreed. Seems to be the same issue.
    Consult your log files: http://www.zen-cart.com/content.php?124-blank-page
  1. problem about edit products details(responsive_sheffield_blue)
    By cmike in forum Customization from the Admin
    Last Post: 6 Jul 2016, 10:49 AM
  2. problem about edit products details(responsive_sheffield_blue)
    By cmike in forum Templates, Stylesheets, Page Layout
    Last Post: 11 Jun 2016, 08:39 AM
  3. Replies: 3
    Last Post: 11 Jan 2011, 02:53 AM
  4. after_process function problem - in custom module
    By myshol in forum Built-in Shipping and Payment Modules
    Last Post: 13 Oct 2009, 01:25 PM
  5. UPS Module Problem in admin: Call to a member function get_template_dir() on a non-ob
    By bbemis in forum Built-in Shipping and Payment Modules
    Last Post: 10 Sep 2008, 06:53 AM
