[Note: remember to include site URL, ZC version, list of plugins, PHP version, etc ... read the Posting Tips shown above for information to include in your post here.
And, remove this comment before actually posting!]
Bone stock install with only EP4 installed.
Trying to set not to show quantity boxes. The attached images show how two PNs are configured and how they display online
TY...Im not sure where to look on what might be wrong.
PHP Version 8.1.2-1ubuntu2.14
System Linux mediaserver 5.15.0-69-generic #76-Ubuntu SMP Fri Mar 17 17:19:29 UTC 2023 x86_64
Build Date Aug 18 2023 11:41:11
Build System Linux
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php/8.1/apache2
Loaded Configuration File /etc/php/8.1/apache2/php.ini
Scan this dir for additional .ini files /etc/php/8.1/apache2/conf.d
Additional .ini files parsed /etc/php/8.1/apache2/conf.d/10-mysqlnd.ini, /etc/php/8.1/apache2/conf.d/10-opcache.ini, /etc/php/8.1/apache2/conf.d/10-pdo.ini, /etc/php/8.1/apache2/conf.d/15-xml.ini, /etc/php/8.1/apache2/conf.d/20-calendar.ini, /etc/php/8.1/apache2/conf.d/20-ctype.ini, /etc/php/8.1/apache2/conf.d/20-curl.ini, /etc/php/8.1/apache2/conf.d/20-dom.ini, /etc/php/8.1/apache2/conf.d/20-exif.ini, /etc/php/8.1/apache2/conf.d/20-ffi.ini, /etc/php/8.1/apache2/conf.d/20-fileinfo.ini, /etc/php/8.1/apache2/conf.d/20-ftp.ini, /etc/php/8.1/apache2/conf.d/20-gd.ini, /etc/php/8.1/apache2/conf.d/20-gettext.ini, /etc/php/8.1/apache2/conf.d/20-iconv.ini, /etc/php/8.1/apache2/conf.d/20-intl.ini, /etc/php/8.1/apache2/conf.d/20-mbstring.ini, /etc/php/8.1/apache2/conf.d/20-mysqli.ini, /etc/php/8.1/apache2/conf.d/20-pdo_mysql.ini, /etc/php/8.1/apache2/conf.d/20-phar.ini, /etc/php/8.1/apache2/conf.d/20-posix.ini, /etc/php/8.1/apache2/conf.d/20-readline.ini, /etc/php/8.1/apache2/conf.d/20-shmop.ini, /etc/php/8.1/apache2/conf.d/20-simplexml.ini, /etc/php/8.1/apache2/conf.d/20-sockets.ini, /etc/php/8.1/apache2/conf.d/20-sysvmsg.ini, /etc/php/8.1/apache2/conf.d/20-sysvsem.ini, /etc/php/8.1/apache2/conf.d/20-sysvshm.ini, /etc/php/8.1/apache2/conf.d/20-tokenizer.ini, /etc/php/8.1/apache2/conf.d/20-xmlreader.ini, /etc/php/8.1/apache2/conf.d/20-xmlwriter.ini, /etc/php/8.1/apache2/conf.d/20-xsl.ini, /etc/php/8.1/apache2/conf.d/20-zip.ini
PHP API 20210902
PHP Extension 20210902
Zend Extension 420210902
Zend Extension Build API420210902,NTS
PHP Extension Build API20210902,NTS
Debug Build no
Thread Safety disabled
Zend Signal Handling enabled
Zend Memory Manager enabled
Zend Multibyte Support provided by mbstring
IPv6 Support enabled
DTrace Support available, disabled
Registered PHP Streams https, ftps, compress.zlib, php, file, glob, data, http, ftp, phar, zip
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, tls, tlsv1.0, tlsv1.1, tlsv1.2, tlsv1.3
Registered Stream Filters zlib.*, string.rot13, string.toupper, string.tolower, convert.*, consumed, dechunk, convert.iconv.*
