Page 4 of 4 FirstFirst ... 234
Results 31 to 33 of 33
  1. #31
    Feb 2009
    Default Re: Use Of Notifiers - How To
    A number of things were addresed with respect to notifiers in v1.3.9. Have you tested the same thing in the latest version of Zen Cart yet?
    Sorry, I hadn't tried it, and should have before posting.
    I'm not sure I'll have time or willpower to look at completely upgrading this 1.3.8a to 1.3.9. This shop has been installed for 4 or 5 years and has had some quite extensive hacking done to it before I started work on it, so even where the override system was followed, the job of merging the hacks into the 1.3.9 file base seems insurmountable.
    However, I'm happy to code against the 1.3.9 model.. I just need the same code to work on my 1.3.8a shop.
    I was hoping to determine what's wrong with this 1.3.8a installation, in terms of how the code is going wrong, and fix it up. The other Zen Cart I will be migrating the same code to is a much more recent one and hopefully won't suffer from this bug. Diff shows some fairly simple modifications to class.base.php, some kind of StaticObserver code that looks like it fixes the problem I identified above. It looks like there is now a single static array of observer info, which stores references to all the different 'base'-derived objects that registered for notifications.
    I wonder if I'll be safe just taking the 1.3.9f class.base.php and using it in a 1.3.8a Zen Cart? it looks pretty safe :) I'll try it soon.
    Nick
  2. #32
    3
    Quote Originally Posted by neekfenwick View Post
    If you're comfortable keeping up a site that's using software with known security vulnerabilities, then that's your call I guess.
    http://www.zen-cart.com/forum/showthread.php?t=150127
  3. #33
    Feb 2009
    Fair point. I've applied the applicable security patches over the past two years, and will rename my admin directory .. I think I'm keeping up with security concerns.
    Wonderful.. shame I didn't see that thread before. I've changed my class.base.php and everything seems to be working well. It's very refreshing working with notifiers and not having to hack core code! :) I'm having to re-write some of my work to make it work in this new way, but I'm sure I'll be left with a cleaner, better, shinier final product.
    A clarification on http://www.zen-cart.com/wiki/index.p...er_is_watching would be nice, to make it clear why 1.3.8 code had to use $_SESSION['cart']->attach instead of $this->attach, referencing the changed base class implementation. I don't seem to be able to create a user account to edit the wiki.
    Thanks again.
