Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 204
    Mar 2005
    Default Re: Info/Orders at a Glance Admin Contribution for 1.2.7 and 1.3.0.
    Hi Woody,
    I meant your spleing is as gud as mne sometimes. Dont worry.
    The mod states its for 1.3.0 not 1.3.0.1
    I will upgrade my test site to 1.3.0.1 when I get back and make the relevant changes there before uploading it (still stuck at that evil called work).
    I have no idea why the icon doesnt show, it shows on my store which has hundreds and every time it displays, maybe you made some changes somewhere along the line?
    I also always recommend modifying code rather than overwriting files as most Zen/Osc stores dont stay stock for more than about 5 minutes.
    As you say it can be modified pretty easily to show whatever you want.
    Mar 2005
    Ok my test site is now 1.3.1 and I implemented the extra fixes in....
    http://www.zen-cart.com/forum/showthread.php?t=34103
    I think ive caught all the problems above and have corrected one or 2 other small issues not noted by Woody.
    Ill get the file uploaded tomorrow after some sleep, its 1.21am here and ive had a hard day
    WONDERFULL! This is a great contrib for ZC. it seems to run flawlessly on my zc1.3 cart. It makes life sooo easy. I need to get a mod that lets me search through orders by part num. But this is a wonderfull addition to our site.
    Thanks and keep up the good work.
    Very happy Mod user
    MYRCS
    Sep 2004
    Shouldn't make any diff as far as I can tell.
    It just doesn't show on a couple orders (missing on appx one out of 30 orders). It shows on the rest. I see no correlation with the orders which are the missing icon. That is what I found strange.
    I also always recommend modifying code rather than overwriting files as most Zen/Osc stores dont stay stock for more than about 5 minutes...As you say it can be modified pretty easily to show whatever you want.
    Yes thats why I would just follow lead of most other mod devs/contributors/porters and not bother with providing those files. Just provide the code which needs inserted and instructions thereof. Easier on everyone, especially when troubeshooitng issues.
    Good job on the port and keep on porting!
    Sep 2004
    Quote Originally Posted by Reesy
    Reesy-
    Could you please post in this thread the bug fixes which I did not refer to. My admin/index.php and /admin/orders.php is heavily customized and easier to edit the files directly. Thanks.
    Woody
    Mar 2005
    Quote Originally Posted by wickedklown
    Very happy Mod user
    MYRCS
    Thanks for your kind comments, Im currently back at the evil called work and cant upload the new file yet but I will be done today.
  7. #17
    Mar 2005
    Quote Originally Posted by Woodymon
    Hi Woody,
    Sorry I have no idea why its not showing on a couple of orders im afraid.
    Ill only provide the new code and new files from now on at your request
  8. #18
    Mar 2005
    Reesy-
    Woody
    Hi Woody,
    You might have an extra <span class=code> in the orders.php code and index.php code that shouldnt be there.
  9. #19
    Sep 2004
    Hi Woody,
    That doesn't appear in the code provided in the readme so all is well.
    So for 1.3.x users just need to edit the code provided in the readme.html per my recommends below.
  10. #20
    Feb 2006
    anyone else download the super orders zip and have the readme file mashed together with no line breaks or spaces?
    or is it just me?
