Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 204
  1. #21
    Dec 2004
    Stockholm
    Default Re: Info/Orders at a Glance Admin Contribution for 1.2.7 and 1.3.0.
    Nice work Reesy
    Asp
    Employing version 1.3.X
  2. #22
    Mar 2005
    Thanks, im happy you found it useful.
    Woody, I figured out what that index.php22 file was, just ignore it and if you dont have any problems with that span class then thats great.
    Unfortunately I didnt even go home yesterday so havent had the chance to upload the correct one but for now follow Woodys post above/below to correct my typos.
  3. #23
    Sep 2004
    Quote Originally Posted by Desopolis
    anyone else download the super orders zip and have the readme file mashed together with no line breaks or spaces? or is it just me?
    Why do you post a question regarding the SuperOrders readme in this thread??
    I have PM'd you a recommendation. Please don't respond here unless specific to 'Info At a Glance Admin" mod.
  4. #24
    Feb 2006
    because this is the thread where super orders was posted, I have read other threads on it, but THIS is the most current mention, also where I got the link..
    sorry to clutter
  5. #25
    Mar 2005
    No problem, but I have only about 3 minutes experience of that mod, I suggest you start another thread or something or use the search where theres about a squillion posts related to it....
    http://www.zen-cart.com/forum/search.php?searchid=12721
  6. #26
    Mar 2005
    The the problem you have is because you opened the zip directly instead of saving it to your hard drive then opening it. Try saving it first then opening it and if you have any other problems post in a related thread or start a new one.
  7. #27
    Mar 2005
    Getting back to the thread...
    I have just returned home.
    Please find the attached corrected file V1.1 ;)
    It includes all the fixes, mentioned in this thread, credits to Woody, updated files and other details how to modify this a little.
    I would still advise adding the code manually.
    Now Ive worked out how to post images on the new forum, heres a couple of screenshots from the readme.
    Scrolling over the new icon (1), shows the javascript box (2).
    Index Page...
    Orders Page...
    If Ive made any mistakes or you notice anything wrong please PM me.
    Attached Files Attached Files
  8. #28
    May 2005
    Brussels belgium
    Hi Reesy,
    Must I change somthing to you code to put your contrib into my zen 1.2.5d?
    greetz
    Chris
    Zen cart or nothing !!
  9. #29
    Mar 2005
    To be honest, I have no idea as that is quite an old release and before I started working with zen cart.
    I would recommend adding the code manually and not overwriting the files for an older release.
    Good luck and let me know how it goes.
  10. #30
    May 2005
    Brussels belgium
    Hi ,
    I've Changed the code into my admin (index.php) and 1 good thing I don't received any error !!) Now I can see the new icon and if I put my cursor over the icon ,I can see in the status bar this "javascript:void(0);" put nothing append
    do you have a ID?
    thanks in advance
