Can anyone help me, I've tried to modify the code so that if the tracking number is entered like this
JA 4356 2421 2GB
It would store it in the database as
JA435624212GB
When I tried my modification it didn't strip the whitespace.
Sorted it out, had to modify a class file.
Installed on v1.5.4. All seems to be working well. A nice addition.
Ty Package Tracker v3.1.4 being submitted to the downloads today.. In the meantime if you need it, you can go to the Github repo: https://github.com/DivaVocals/zen_Ty...ses/tag/v3.1.4 (choose either the "Source code (zip)" or "Source code (tar.gz)")
Also I MAY create a new support thread.. This one is probably a LOT long in the tooth..
Use this link instead to see all releases: https://github.com/DivaVocals/zen_Ty...acker/releases
Hello.
I will install this plugin on zen cart 1.5.4. I have questions regarding admin/orders.php
1) is the file from the plugin based from the 1.5.4 version of orders.php? Comparing using winmerge, i can see that there are differences in the location of some lines of html code not related to the plugin's specific code edits. There are also differences in html structure like some use a <div> in the plugin file but not in the 1.5.4 file. Are these changes created intentionally for the plugin or are they from a previous version of orders.php?
2) are all ty package tracker edits labeled inside the file because there are some unlabeled codes that are not present in the 1.5.4 file. I'm not sure if I need to copy those parts to the 1.5.4 file.
3) if i don't have previous edits done on the 1.5.4 file, is it ok to just overwrite the whole file with the plugin's own version?
By the way, i'm not using super orders or edit orders plugins.
Hope someone can guide me. Thanks
anyone who can help?
