Results 1 to 8 of 8
    May 2006
    Problem after fresh installation ion IIS6
    I've just installed the newest zen-cart version on a dedicated Windows-Server. I can log into the admin-account and do all the configuration, but I can't open the normal shop-address. This gives the following error-message:
    Call to a member function get_template_part() on a non-object
    (Line 29 in index.php)
    Any idea?
    For testing, this ist the URL:
    http://shop.pferde-im-visier.de
    At the moment, I didn't delete the zc_install Directory and both config-files are writable. So feel free to change some settings if you see an error.
    Many thanks for your help!
    Thommy
    Default Re: Problem after fresh installation ion IIS6
    You could have either bad or corrupted files loaded ...
    Try reloading the files from a good copy of Zen Cart v1.3.0.1 that you can get from here ...
    See if that doesn't help ...
    NOTE: save your files from the website for:
    /includes/configure.php
    /admin/includes/configure.php
    so as not to overwrite the ones on the website ...
    May 2006
    now, I've downloaded the newest version directly from your web-site (last time I loaded the german version from your austrian site), and made a completely new installation,- but the problem still exists. The same error-message as before.
    Thommy
    3
    Thommy,
    I suspect your configure.php files are the problem.
    Can you post your /includes/configure.php file contents here, without the passwords?
    May 2006
    Sure, here it comes:
    define('HTTP_SERVER', 'http://shop.pferde-im-visier.de');
    define('HTTPS_SERVER', 'http://shop.pferde-im-visier.de');
    define('DIR_WS_HTTPS_CATALOG', 'https://shop.pferde-im-visier.de/');
    define('DIR_WS_PHPBB', '/');
    define('DIR_FS_CATALOG', 'D:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\inetpub\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\piv-online/');
    define('DB_TYPE', 'mysql');
    define('DB_PREFIX', '');
    define('DB_SERVER', 'localhost'); // eg, localhost - should not be empty
    define('DB_SERVER_USERNAME', 'xxxxxxx');
    define('DB_SERVER_PASSWORD', '****************');
    define('DB_DATABASE', 'pivshop');
    define('STORE_SESSIONS', 'db'); // leave empty '' for default handler or set to 'db'
    define('DIR_FS_SQL_CACHE', 'D:/cache');
    3
    a few things I'd recommend updating:
    change these lines:
    define('DIR_WS_HTTPS_CATALOG''https://shop.pferde-im-visier.de/');
    define('DIR_FS_CATALOG''D:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\inetpub\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\\piv-online/');
    define('DIR_FS_SQL_CACHE''D:/cache');
    to:
    define('DIR_WS_HTTPS_CATALOG''/');
    define('DIR_FS_CATALOG''D:/inetpub/piv-online/');
    May 2006
    unfortunately this doesn't help.
    I made the changes and when I now try to open the shop-url, I am redirected to the admin-URL. When I use the link "Online Catalog" in the admin-area, I get the following error-message:
    Warning: require(DIR_WS_TEMPLATEStemplate_default/common/html_header.php) [function.require]: failed to open stream: No such file or directory in D:\Inetpub\piv-online\index.php on line 43
    Fatal error: require() [function.require]: Failed opening required 'DIR_WS_TEMPLATEStemplate_default/common/html_header.php' (include_path='.;c:\program files\php5\includes') in D:\Inetpub\piv-online\index.php on line 43
    Thommy
    Aug 2004
    define('DIR_FS_CATALOG', 'D:/inetpub/piv-online/');
    change to:
    define('DIR_FS_CATALOG', 'D:\\inetpub\\piv-online\\');
    define('DIR_FS_SQL_CACHE', 'D:\\cache');
    it usually takes two ' \\ ' from the web under Microsoft Windows Server access (no matter which edition or build it might be).
    In the mean time, I have also found two other errors from your file's readings above.
    If this line is set to a secured protocol (HTTPS):
    then, I assume this one should also be set under SSL as well:
    define('HTTPS_SERVER', 'https://shop.pferde-im-visier.de');
    As for this one:
    There's a missing front-slash according to this error message.
    If you change:
    into:
    define('DIR_WS_INCLUDES', '/includes/');
    (as a test only) - will the error message appear again ?
