I have a problem with upgrading to 1.3.0.1, where the page loads half way and stops, refreshing once or more will make it load correctly. This is not a situation that a live store could live with. I do not have this problem with my current store that is ZenCart 1.2.6.
I need to correct this before I can make the upgraded site live but have not a clue as to what might be causing this. I have reloaded the cart files thinking that there might be a corrupt file.
If you would like, see my current store at http://www.designsbyj3.com
My upgraded site at http://www.designsbyj3.com/zen13
If you are lucky, it will load ok to the home page, but this is not a predictable problem, browse the categories and there will be an instance of the half load that you can see.
The screen shot is where it loads half way - it will then load properly after several refreshes.
I would really appreciatte any help you maybe able to give me at this point, I am stumped!
