Hi guys,
Well I made a lot of progress, I got everything up and running and it's working (yeah!!). I'm not using overrides at this time but I plan on re-creating the cart in another directory later and taking my time and doing things right on that one.
So basically I've been modifying the files at
/includes/languages/english/classic/
/includes/languages/english/html_includes/classic
Anyway, I'm having a problem with the link colors on my site. I went into the .css files and changed everywhere I could find that default light-blue link color code, and replaced it with a burgundy color code.
The strange problem is that *some* links have changed to burgundy, some haven't (in the same sections! ie - product listings, some are blue, some are burgundy!)
For example, if you go to my site at http://www.getqlink.com/
and click on the "Q-Link Pendants" category, you will see that some of the products listed have a light blue link, and some have a burdundy link. I can't understand why they have different color settings, I would think one change in the appropriate css file should have changed all of them (or none of them if I changed the wrong code, but SOME of the links in the same section?)
Does anyone know which CSS file and which specific entry affects these other link colors?
Lastly, the link colors in the sidebars under 'Information' and 'More Information', which .css file / entry controls that color? I also want to set that to burgundy.
Nathalie
