Brings a tear to my eye when they leave the nest for their first flight......
Mike
Camelot-Hosting...A PCI compliant Ecommerce Host
LOL thanks again everyone!
Unfortunately, I read this after I have already done a good bit of customization on the classic template.
Would it be possible for me to just copy the classic folder that I have customized and name it classic_new or something like that?
Would that then be my "override" folder?
And then the includes/languages/english/classic/header.php file would be put in that classic_new folder? Or would I make an includes/languages/english/classic_new/ folder and put the header.php file that I've customized into that?
The same with any file that I've customized that has to do with the classic template?
Am I getting it? LOL... I'd just hate to think that all the work I've done so far would be wasted if I upgrade.
Thanks for any advice.
Mary Ellen
I came; I saw; I Zenned
Taking over the world... one website at a time
Make sure brain is engaged before putting mouth in gear... or fingers to keyboard.
Holzheimer
Fan Odyssey
The overall process of getting a page of content to display includesWhy does, what seems like, straight forward processes have to be chopped up into hundreds of disparate bits and pieces that make it impossible to see the big picture? Why? Why?
- examing the URL request
- getting stuff from the database
- assembling the HTML header
- assembling the navigation bar
- assembling links to images
- assembling the on-page content
- grabbing the language-dependant buttons and links
- sending the page to thebrowser
You have to do all of the database stuff before you send anything out to the browser, therefore stuff will be spread out through several parts of the code.
A large number of blog and cart systems start sending HTML out to the browser before they have even decided which records to read from the database. Those systems are unable to send a proper 404 error when there is nothing in the database for the requested page number!
ZenCart, like many other advanced web applications, is a very intricate system catering for a wide variety of e-comm needs, and for most people various functions and chunks of template will be discarded.
Additionally, if the code were one long file it would be impossible to work on.
Hi i was wondering if i can override tpl.header. I tried many stuff but only with override the actual file is working for me..any ideas?
Yes. Overriding /includes/templates/template_default/common/tpl_header.php is as simple as copying that file to your own custom template folder and making the changes there.
ie: put the file at /includes/templates/NAME_OF_YOUR_TEMPLATE_FOLDER/common/tpl_header.php
Hi. Well i do have already my own custom template so my directory is: includes/templates/enk_sales/common/tpl_header.php so i guess i should just make changes there and thats it. I just wanted to not override my own custom template just in case i make a coding mistake. BUt i guess the best way is just to rename the file im changing and upload the new one...
Do you have a better way maybe?
Also another small question. When i upload products images do i upload them to /images/large and also /images/medium because i did upload them to just the images folder it self and i had to create another images folder inside the image for me to see them in the store. images/images...
