hi everyone
i have a problem uploading the "Zen cart the art of e-commerce" sites. when i load the site up it output this message below it loads up okay but at the top of the web page it output the warning messages, which i don't understand:
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 134
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 149
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 153
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 157
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 235
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 263
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 267
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 358
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 380
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 384
Warning: ini_get, ini_alter, ini_restore, ini_set, getrusage, mysql_list_dbs, get_current_user, set_time_limit, getmyuid, getmypid, dl, leak, listen, chown, chmod, chgrp, realpath, tmpfile, link, mb_send_mail() has been disabled for security reasons in /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/includes/modules/pages/inspect/header_php.php on line 388
:: Zen Cart™ Setup - System Inspection
Take a moment to check whether your webserver supports the features required for Zen Cart™ to operate. Please resolve any errors or warnings before continuing. Then click on Install to continue.
System Inspection Results
Webserver = Apache
HTTP Host = members.lycos.co.uk
Path_Translated = /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/zc_install/index.php
PHP O/S = Linux
PHP API Mode = cgi Click here for more info
PHP Max Execution Time per page =
Register Globals = OFF
MySQL Support = ON
MySQL Version = Unknown Click here for more info
PHP Version = 4.3.2
PHP Safe Mode = OFF
PHP open_basedir restrictions =
PHP Sessions Support = ON
PHP Session.AutoStart = OFF
PHP session.use_trans_sid = OFF
Suggested SQL Cache Folder = /data/members/free/tripod/uk/g/a/d/gadgetbox/htdocs/cache
PHP magic_quotes_runtime setting = OFF
PHP GD Support = ON
GD Version = GD 2.0 or higher
PHP ZLIB Compression Support = ON
PHP cURL Support = OFF
PHP Upload Support = OFF upload_max_filesize=; post_max_size= Click here for more info
PHP Upload TMP dir =
PHP XML Support = ON
View PHPINFO for your server Other System Information (For Reference Only)
The following info does not necessarily indicate any problem or configuration issue. It is simply for the sake of displaying it in an easy-to-find location.
PHP Session.Save_Path = Unknown
PHP sendmail 'from' =
PHP sendmail path =
PHP SMTP destination =
File and Folder Permissions
In order for many Zen Cart™ administrative and day-to-day functions to work properly, You need to mark several files/folders "Writeable". The following is a list of folders which need to be "read-write", along with recommended CHMOD settings. Please correct these settings before continuing installation. Refresh this page in your browser to re-check settings.
Some hosts may not allow you to set CHMOD 777, but only 666. Start with the higher setting first, and switch to lower values if required.
includes/configure.php = Writeable
admin/includes/configure.php = Writeable
cache = OK
images = OK
includes/languages/english/html_includes = OK
media = OK
pub = OK
admin/backups = OK
admin/images/graphs = OK
Welcome License Prerequisites System Setup phpBB Setup Database Setup Store Setup Admin Setup Finished
Copyright © 2003-2006 Zen Cart™
here is the site address to see what i mean http://members.lycos.co.uk/gadgetbox...nguage=english
i would welcome any solution to this problem please help me out,
regards
Nikesh
