Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 44
    Default Re: Problem with images!!!
    Hi! I'm experiencing the same problem. All product images in one particular category is not showing up. I tried uploading the file images using filezilla, dreamweaver and file manager of my site but still no luck.
    I have not altered any of the template file...
    The URL is http://disenyoartsusa.mnm.ph/shop/in...=index&cPath=1
    Hope somebody could help me..
    Your base image is:
    /images/tiles/D001.jpg
    This means the LARGE image should be:
    /images/large/tiles/D001.jpg
    You have it in:
    /images/large/D001_LRG.jpg
    Your base image is:
    You have it in:
    I'm just experimenting D001 if I place it in different folder it will solve the issue, well I guess not...
    The rest of the images are..
    images/
    images/large
    images/medium
    The only product displaying is D001 and rest images of the images are blank...
    What is weird about the problem is that everytime I create a new zen-cart install the same problem occurs with that particular product category, Anthology.
    The rest of the category working perfectly, http://disenyoartsusa.mnm.ph/shop/in...=index&cPath=3
    Hope somebody can advise me on what to do because I need to launch the site in the next couple of days.
    Please look in your products table via phpMyAdmin ...
    Do you see the image filename or do you see a subdirectory of /images plus the filename?
    If you see basename.ext ... the directories are:
    /image/basename.ext
    /image/medium/basename_MED.ext
    /image/large/basename_LRG.ext
    If you see something/basname.ext ... the directories are:
    /image/something/basename.ext
    /image/medium/something/basename_MED.ext
    /image/large/something/basename_LRG.ext
    And make sure the permissions are correct on all of the directories ...
    Oct 2006
    Assuming you used the templates and overrides and did not alter the original default files ...
    Switch to Classic ...
    Does this work correctly now?
    sadly, it does not
    Have you an URL to a Product and the directory/image files that you think you have setup for this product?
    i will private message it to you
    thank you in advance for your help
  7. #17
    Your base image needs to be:
    /images/cards/NC6CORPSE.jpg
    Not:
    /images/cards/NC6CORPSE_01.jpg
    Medium is :
    /images/medium/cards/NC6CORPSE_MED.jpg
    Large is then:
    /images/large/cards/NC6CORPSE_LRG.jpg
    The additional images then build from there like you have it ...
    Note: there is only 1 Medium image for display on the Product Info page ...
  8. #18
    Its the image filename that is in the database.
    All files are uploaded in their right directories and permissions are correct. I dont know why but its only one category that is acting up this way, the rest are working perfectly.
  9. #19
    Dec 2006
    Victoria, Australia
    I am afraid I too am having no luck with multiple images.
    I uploaded my images into the following directories (CMOD 777)
    images/products/picture.jpg
    images/medium/products/picture_MED.jpg
    images/large/products/picture_LGE.jpg
    I also tried:
    images/medium/products/picture.jpg
    images/large/products/picture.jpg
    In administration I edited the product page in both IE & Firefox and it made no difference.
    I tried moving it another catagory and still no luck
    I made sure that in product settings is was allowing multiple images also.
    I am lost - Is this option really available? I am using v1.3.6
  10. #20
    Is this a typo?
    Have you an URL that we can peek at and a real Product that is using this method?
