    Nov 2006
    application error Special Products beforNew Products of the month and delete product with quantity zero
    Question 1) I would like that in "Home Page" the Specials Products must position befor the new products of the month..... which file must change? and how it edit?
    Question 2) I would like to delete from the database all products with quantity equal to zero.....exists a fast method?
    P.S. Excuse me for any grammatical errors! I'm italian!
    Default Re: Special Products beforNew Products of the month and delete product with quantity
    To sort the Centerboxes ... go to the Configuration ... Index Listing ...
    There are "sets" of centerboxes that you can sort ...
    0 means OFF and any other value is the Sort Order to display order of the centerboxes ...
    To completely remove from the database all products with a products_quantity of 0 ... it is really safer to do via the Admin as there are many database tables associated with each Product and the Admin delete of a Product will manage this for you ...
    How many Products do you have that you want deleted?
    Nov 2006
    Our company has a supplier who will send us their database as a text file which contains many products with quantity equal to zero and i use EasyPopulate for to add the products in my database. Now, i would like to delete all products with quantity to zero..... it is possible to do via the Admin ??? or else, if i make a PHP programm for to delete all this products, which database tables i must consider?
    I hope is all clear!
    It would be best to write a program to delete the product based on the delete routine that a standard delete makes ...
    If you are importing a file with quantity 0 ... can't you just delete those before you import?
    Nov 2006
    Bhè! Yes! But i had to think to us before adding the products! By now i have make the damage!
    You might peek at the file:
    /admin/includes/modules/delete_product_confirm.php
    NOTE: Backup your database before you try to apply your own script to clean up the database tables ...
