Well I found the answer to no shopping cart here:
http://www.zen-cart.com/forum/showth...278#post300278
Thats that but I would appreciate an answer to the question above thank you
after all my username is "blind 1"
You just said "too tight on main folder" and then you quoted two filenames. Folders and filenames are different.
The instructions for setting permissions talk about certain settings for folders, and other settings for certain files. Did you follow those exactly? What exactly did you set each of those to?
Nothing in the permissions documentation talks about the /admin/configuration.php file. As such, it should be treated as any other non-mentioned file.
OK THANK YOU.
I fixed it all and have been having a ball with it. (first-timer)
Now I have a new challenge.
I reset the password for the admin and wrote it down but for some reason it wont let me in now.
I tried clicking the email a reminder but it doesn't accept my email.
I am really panicked over this one.
For that, I will direct you to the FAQ system or the Forum Search facility:
https://tutorials.zen-cart.com
http://www.zen-cart.com/forum/search.php
WHOOPS-I meant directory not folder
BEGGING FOR HELP NOW - REALLY BEGGING
I am on my second day trying to solve my lock out issue.
Have posted these yesterday 7.12.06 with no answer:
http://www.zen-cart.com/forum/showthread.php?p=300694#post300694
http://www.zen-cart.com/forum/showth...728#post300728
If there is no way out of this I guess i will have to start again.
If I do in stall fresh, what files/direcories can I copy across/replace from the work I have already done already to save reworking every setting, content, images again!
Pretty please!
