On the admin side choice configuration / Product Info and select Also Purchased Products Columns per Row
Also Purchased Products Columns per Row can be set from 1 to 12 but not back to 0 to let the also bought items disappear ;)
Simply set your Maximum Values setting for Also Purchased Products to 0 if you wish to disable the output.
Key: MAX_DISPLAY_ALSO_PURCHASED
Please make any necessary changes
Number of products to display in the 'This Customer Also Purchased' box
Sorry - not a bug. The Setting to not show is in Admin> Cofiguration> Maximums
Oke, thanks, i was confused by the description
0= off or set the sort order
aha - that makes sense -- will investigate that for future.
