    Dec 2006
    Default Product display problem after upgrade
    Hi, just trying out the upgrade from 1.3.5 to 1.3.7 and it was all going fine until I went to view a product. The category product listings are fine but when you view a particular item (doesn't matter which) you don't get the full page.
    I get no right-hand column boxes and the page just stops (no product info or footer)
    Any ideas??
    Jun 2003
    Default Re: Product display problem after upgrade
    Compare your tpl_product_info_display.php to a clean one from the distribution.
    Dec 2006
    Hi Kim, it's exactly the same and I haven't overridden it!
    Any ideas?
    Dec 2006
    Ah, just sorted it. I had an override for tpl_modules_main_product_image.php and it was calling the lightbox script that I hadn't installed on the 'upgrade'!
    I found this out by doing a 'View Source' on the page and it showed an error on there if anyone else has a similar problem.
  1. Problem adding new field to product listing
    By rwoody in forum General Questions
    Last Post: 9 Oct 2006, 08:04 AM
  2. Product Listing - prev/next broken....?
    By oceano in forum Basic Configuration
    Last Post: 26 Sep 2006, 12:31 AM
