    Aug 2006
    Default Problems after the upgrade. HELP !
    please check my store www.gotbidet.com
    after the upgrade it is all messed up.
    it looks OK from admin side, but the front is no good.
    no products, text, template is off, browser header is messed up.
    search and categories are all messed up.
    please help.
    Mike.
    Jun 2005
    Cheney WA
    Default Re: Problems after the upgrade. HELP !
    Ok,
    You went too deep with your template overide system.
    /home/bidet/public_html/store/includes/templates/gotbidet/templates/tpl_index_default.php
    should be
    /home/bidet/public_html/store/includes/templates/gotbidet/tpl_index_default.php
    Nice photo on the header. I feel like I'm kayaking.
    You need to take the border off you header photo. Make the value of the boarder 0.
    You also need to bring down the optimization to about 30, or 40 if you experiance some image degredation.
    John Patrick
    A Zen Cart Advocate!
    Jun 2003
    Looks like a bad upload, reupload the /includes/ directory using a good FTP program.
    Aug 2006
    i reloaded the folder as per your recomendation.
    this is how it looks like now:
    www.gotbidet.com
    please help.
  1. EPDQ module problems after 1.2.7-1.3.6 upgrade
    By mangetouts in forum Upgrading from 1.2 to 1.3.x
    Last Post: 24 Sep 2007, 12:10 PM
  2. database upgrade problems
    By keystonewebworks in forum General Questions
    Last Post: 13 Oct 2006, 02:44 AM
  3. Error after upgrade
    By bfwdesigns in forum Upgrading from 1.3.x to 1.3.9
    Last Post: 7 Sep 2006, 02:17 AM
