Page 5 of 8 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 79
  1. #41
    Aug 2006
    portlandish, oregon
    Default Re: Product Listing Default Sort Order
    I am having a bit of a different problem....I applied the fix for products to default to Newest to Oldest, however...This also ignored the product's sort orders.
    I need my product display to go by Product sort order, and if it's not specified on the products, to display newest to oldest.
  2. #42
    Feb 2010
    Quote Originally Posted by oscar View Post
    Follow up to this thread.
    Can you sort by model number without displaying it in the product listing?
    Was it ever determined if this was possible?
    I have searched and haven't seen an answer.
  3. #43
    Feb 2010
    Quote Originally Posted by rubbercarp View Post
    Nevermind. I would up configuring EasyPopulate to include the Sort Order field. It is a perfect work around.
  4. #44
    May 2008
    Quote Originally Posted by HelenSama View Post
    I am having problems with this and have read this post and others as well as tried various things, I hope I am just missing something and someone can help me with this ---- The URL is http://blockislandhoney.com/ go to either Candles or Novelties to see the problem, For example Novelties, The product listing page is set up in the correct order that my client wants it to be, I used SORT ORDER field to do this, However, when you click on the Yoga CD, the first product, you go to it's product page and it says it is Product 4/7.... It should be 1/7.... then if you click on Next you should see the Calendar which is the next product on the Product Listing page and according to the sort order, but you don't see the calendar. Any general or specific help would be appreciated, if you need to know more about various settings I can provide the information.
    Hi, has anyone solved this please? I have the same problem...
  5. #45
    Feb 2009
    I'm still baffled too. I want the products to display lowest price first. When I click on the "price" on the bar in the actual website to display this order it says "page=1&sort=3a". So I thought, "excellent, I just need to add 3a to each products sort", but it doesn't remember the "a" bit, only the 3. I have searched the forums and have tried different paramaters, but still can't get it to work.
    Any ideas? I'm running 1.3.7 and fully patched
  6. #46
    Aug 2006
    portlandish, oregon
    Well it appears that after updating to v1.3.9d this 'hack' for sort order does not work for me. I JUST went through in Easy Populate and redid the 'added on' date of every product to display it in the order I wanted, and now they are just showing up however they feel like.
  7. #47
    May 2008
    Spent days trying to sort out this ...in includes/index_filters/default_filter.php comment out line 105:
    $listing_sql .= " order by p.products_sort_order, pd.products_name";
    and add the following:
    $listing_sql .= " order by p.products_date_added DESC, pd.products_name";
    Hope this helps!
  8. #48
    Mar 2008
    Thank you Ajeh!
    Your answer from 2008 helped me out today!
    In my case: Sort by price is 3a
    Thank you again :)
    Actually, that is a misnomer ...
    The Sort Order is also determined by what your individual columns are in the Product Listing ...
    So your Model might be 1a but mine might be 4a ...
    The better way to know what to use is to go to the Product Listing on your site and click the headers until you are in the right order ... then, look in the URL for the &sort=#x and enter your #x for the sort order ...
  9. #49
    Thanks for the update that this was able to help you get your Sort Order setup correctly ...
  10. #50
    Jun 2010
    Oregon
    admin/config/product listing/Product Listing Default Sort Order is blank
    Which means the sort value seen listed for each category controls the order listed on the page for that Category.
    Function confirmed.
    BUT
    Upon clicking to a product page, the order presented when clicking previous or next is not what I want. They are sorted alphabetically by Product Name.
    How to I match the prev/next order when looking at product pages to the listed order on the Category page?
  1. Product sort order in "All Products..." page by model
    By corrado444 in forum Basic Configuration
    Last Post: 24 May 2011, 05:00 PM
