Results 1 to 5 of 5
    Feb 2006
    Default PaypalFlow Pro Issues
    I wonder if anyone would be so kind as to help or clarify some problems I am facing.
    I recently just transferred from unix to windows, and I am now in the process of setting up the paypal. DrByte kindly has put together a simple plug and play script which works wonderfully, however on windows I am having troubles.
    The error I currently see is:
    "NOTE: Module binaries not executable or lib path not found"
    The files are there and I have set the user rights for the files and folders accordingly.
    If someone could clarify the following:
    By configuring my PHP build with pfpro, do I just stick pfpro.dll in the extensions folder and reference it in the php.ini, i.e 'extension = pfpro.dll'? - My phpinfo() doesnt show pfpro, though I am sure it is there, along with the COM component.
    The pfprolb.so, is an apache file, correct?, do I need to replace the bin and lib folders witht he windows equivlent fromt he SDK? - I have tried this but no luck.
    Any pointers would be great. As said I keep geeting the preceeding error, and when I do a complete authorization I get "result code: -1".
    Much appreciated,
    Kurt
    7
    Default Re: PaypalFlow Pro Issues
    The PayflowPro contribution download page has a few different versions ... a couple updates have tweaks for windows support. I haven't tested the windows support in them in order to vouch for their reliability. But you might try checking the various versions to see if things work better. The readme in the latest version contains a note that mentions the need to add your pfpro binaries to the windows PATH, so you might want to check that out also.
    Feb 2006
    Wonderful, thank you yet again DrByte! I found the c4 revision that ghas been modified for a windows enviroment. I now have a bigger understanding. I will let you know how I get on.
    !Thanky ou!
    Feb 2006
    K Cool. No more bin or lib errors. Just the "Result Coide: -1" After a test purchase.
    Feb 2006
    Well don't ask why but I was reluctant to dive into the osurce for some reason. Plainly because of the fact I thought it wasn't working because of 101 problems.
    HJowever in the source DyByte had some nice debug modes added - nice touch BTW. Thankfully this narrowed it down to the fact the script thought I was running LINUX, instead of finding out why I just took out the IF statements so the COM component would execute.
    Lovely jubley all fixed :)
    DrByte.. Thank you for your excellent contribuitons and extensible scripts.
  1. Payflow Pro Module issues
    By abcisme in forum Built-in Shipping and Payment Modules
    Last Post: 24 Dec 2014, 07:05 PM
  2. Paypal Pro issues -- error (1)
    By opnes in forum PayPal Website Payments Pro support
    Last Post: 10 Sep 2009, 06:17 PM
  3. Clarifying ZC issues w/ Web Site Payments Pro: It doesn't work yet in v1.3.7
    By teksimple in forum PayPal Express Checkout support
    Last Post: 20 Mar 2007, 01:01 AM
