Results 1 to 8 of 8
    Nov 2006
    Default Need help to change this TEXT seems a unique problem
    I can't find the text I am looking for in Header.php ---It is not "Sales Message goes here" file - It.s a html file - see below:
    www.mikeslumber.com/cart/ -- on the main page -- look in the source code -- -------------------------------------------------------------
    find the text below -- I want to change "Welcome to "Mikes Lumber....."
    </td></tr></table></td>
    <td valign="top" class="center_column" width="100%"><table border="0" width="100%" cellspacing="2" cellpadding="2">
    <tr>
    <td class="pageHeading"><h1>Welcome to mikes Lumbers & Hardware Store We are under Construction we expect to go online in about 2 months</h1></td>
    </tr>
    <tr>
    <td class="greetUser">Welcome <span class="greetUser">Guest!</span> Would you like to <a href="http://mikeslumber.com/cart/index.php?main_page=login">log yourself in</a>?</td>
    </tr>
    Where do I find this file???? I spoke with someone who said they edited this line in their FTP client while online - I don't have an FTP client that allows editing online.
    Jan 2005
    USA, St. Louis
    Default Re: Need help to change this TEXT seems a unique problem
    Quote Originally Posted by Shadow View Post
    <tr>
    </tr>
    <tr>
    </tr>
    Whenever you're looking for text like that, go to your admin, go to "Tools", "Developers Tool Kit". Search for a portion of the text, for example, search for:
    I always enter my search term into the last input box, then choose "All Files - Catalog" from the drop down menu.
    That will tell you exactly what file its located in.
    This text has been edited before, as that is not the default text. You either need to download a free FTP client, OR find out what your control panel is for your website... most hosts offer an online control panel so you can edit your files through your browser.
    Nov 2006
    Nov 2006
    You may have to paste- www.mikeslumber.com/cart/ into your -browser
    Jan 2005
    USA, St. Louis
    Did you read my post above? It still applies, no matter the link to your site.
    Nov 2006
    Thanks Jettrue - I followed your instructions & found the filename in the Define Editor & will change it tommorrow. "Shadow"
    N of San Antonio TX
    Just a note about the Developers Tool Kit in the admin. It is designed to search for text and key words that have been hard-coded into existing files. It will not search the database nor find, for example, the store name after being parsed into an html file. Even some of the greetings are broken up into two selections in the php files.
    Start small when searching and try to avoid terms you've entered during setup or in product namess/descriptions. You'll find it to be a valuable tool in your arsenal.
    Nov 2006
    Default Re:solved text change problem thanks
    I found and changed the text using the toolkit - thanks everbody - --Shadow--
  1. v139h Need help undoing this SQL change
    By StoreOwner in forum General Questions
    Last Post: 27 Dec 2014, 04:22 PM
  2. Need Help Locating Text To Change
    By JusMeJim in forum Templates, Stylesheets, Page Layout
    Last Post: 3 Mar 2013, 10:28 AM
  3. Need to set up Unique downloads based on text attributes
    By nyrad in forum Setting Up Categories, Products, Attributes
    Last Post: 5 May 2010, 05:33 PM
  4. Need help to change this TEXT seems a unique problem
    By Shadow in forum Installing on a Linux/Unix Server
    Last Post: 10 Aug 2007, 02:08 AM
