* Common Template
* outputs the html header. i,e, everything that comes before the \</head\> tag <br />
* @package templateSystem
* @version $Id: html_header.php 4368 2006-09-03 19:31:00Z drbyte $
* load the module for generating page meta-tags
require(DIR_WS_MODULES . zen_get_module_directory('meta_tags.php'));
* output main page HEAD tag and related headers/meta-tags, etc
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" <?php echo HTML_PARAMS; ?>>
<head>
<title><?php echo META_TAG_TITLE; ?></title>
<meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET; ?>" />
<meta name="keywords" content="<?php echo META_TAG_KEYWORDS; ?>" />
<meta name="description" content="<?php echo META_TAG_DESCRIPTION; ?>" />
<meta http-equiv="imagetoolbar" content="no" />
<meta name="generator" content="shopping cart program by Zen Cart™, http://www.zen-cart.com eCommerce" />
<?php if (defined('ROBOTS_PAGES_TO_SKIP') && in_array($current_page_base,explode(",",constant('ROBOTS_PAGES_TO_SKIP'))) || $current_page_base=='down_for_maintenance') { ?>
<meta name="robots" content="noindex, nofollow" />
<?php } ?>
<?php if (defined('FAVICON')) { ?>
<link rel="icon" href="<?php echo FAVICON; ?>" type="image/x-icon" />
<link rel="shortcut icon" href="<?php echo FAVICON; ?>" type="image/x-icon" />
<?php } //endif FAVICON ?>
<base href="<?php echo (($request_type == 'SSL') ? HTTPS_SERVER . DIR_WS_HTTPS_CATALOG : HTTP_SERVER . DIR_WS_CATALOG ); ?>" />
* load all template-specific stylesheets, named like "style*.css", alphabetically
$directory_array = $template->get_template_part($template->get_template_dir('.css',DIR_WS_TEMPLATE, $current_page_base,'css'), '/^style/', '.css');
while(list ($key, $value) = each($directory_array)) {
//echo '<link rel="stylesheet" type="text/css" href="' . $template->get_template_dir('.css',DIR_WS_TEMPLATE, $current_page_base,'css') . '/' . $value . '" />'."\n";
* load stylesheets on a per-page/per-language/per-product/per-manufacturer/per-category basis. Concept by Juxi Zoza.
$manufacturers_id = (isset($_GET['manufacturers_id'])) ? $_GET['manufacturers_id'] : '';
$tmp_products_id = (isset($_GET['products_id'])) ? (int)$_GET['products_id'] : '';
$tmp_pagename = ($this_is_home_page) ? 'index_home' : $current_page_base;
$sheets_array = array('/' . $_SESSION['language'] . '_stylesheet',
'/' . $tmp_pagename,
'/' . $_SESSION['language'] . '_' . $tmp_pagename,
'/c_' . $cPath,
'/' . $_SESSION['language'] . '_c_' . $cPath,
'/m_' . $manufacturers_id,
'/' . $_SESSION['language'] . '_m_' . (int)$manufacturers_id,
'/p_' . $tmp_products_id,
'/' . $_SESSION['language'] . '_p_' . $tmp_products_id
while(list ($key, $value) = each($sheets_array)) {
//echo "<!--looking for: $value-->\n";
$perpagefile = $template->get_template_dir('.css', DIR_WS_TEMPLATE, $current_page_base, 'css') . $value . '.css';
//if (file_exists($perpagefile)) echo '<link rel="stylesheet" type="text/css" href="' . $perpagefile .'" />'."\n";
* load printer-friendly stylesheets -- named like "print*.css", alphabetically
$directory_array = $template->get_template_part($template->get_template_dir('.css',DIR_WS_TEMPLATE, $current_page_base,'css'), '/^print/', '.css');
sort($directory_array);
echo '<link rel="stylesheet" type="text/css" media="print" href="' . $template->get_template_dir('.css',DIR_WS_TEMPLATE, $current_page_base,'css') . '/' . $value . '" />'."\n";
* load all site-wide jscript_*.js files from includes/templates/YOURTEMPLATE/jscript, alphabetically
$directory_array = $template->get_template_part($template->get_template_dir('.js',DIR_WS_TEMPLATE, $current_page_base,'jscript'), '/^jscript_/', '.js');
echo '<script type="text/javascript" src="' . $template->get_template_dir('.js',DIR_WS_TEMPLATE, $current_page_base,'jscript') . '/' . $value . '"></script>'."\n";
* load all page-specific jscript_*.js files from includes/modules/pages/PAGENAME, alphabetically
$directory_array = $template->get_template_part($page_directory, '/^jscript_/', '.js');
echo '<script type="text/javascript" src="' . $page_directory . '/' . $value . '"></script>' . "\n";
* load all site-wide jscript_*.php files from includes/templates/YOURTEMPLATE/jscript, alphabetically
$directory_array = $template->get_template_part($template->get_template_dir('.php',DIR_WS_TEMPLATE, $current_page_base,'jscript'), '/^jscript_/', '.php');
* include content from all site-wide jscript_*.php files from includes/templates/YOURTEMPLATE/jscript, alphabetically.
* These .PHP files can be manipulated by PHP when they're called, and are copied in-full to the browser page
require($template->get_template_dir('.php',DIR_WS_TEMPLATE, $current_page_base,'jscript') . '/' . $value); echo "\n";
* include content from all page-specific jscript_*.php files from includes/modules/pages/PAGENAME, alphabetically.
$directory_array = $template->get_template_part($page_directory, '/^jscript_/');
require($page_directory . '/' . $value); echo "\n";
if ($tmp_products_id != '') {}
else { echo '<script type="text/javascript" src="' . HTTP_SERVER . DIR_WS_CATALOG . 'jscript/imagehover.js"></script>'. "\n";}
// DEBUG: echo '<!-- I SEE cat: ' . $current_category_id . ' || vs cpath: ' . $cPath . ' || product id: ' . $tmp_products_id . ' || page: ' . $current_page . ' || template: ' . $current_template . ' || main = ' . ($this_is_home_page ? 'YES' : 'NO') . ' -->';
<!--[if IE]>
<link rel="stylesheet" href="<?php if($this_is_home_page){ echo DIR_WS_TEMPLATE . 'css/ie-index.css'; } else { echo DIR_WS_TEMPLATE . 'css/ie.css';}?>" />
<![endif]-->
<!--[if lte IE 6]>
<link rel="stylesheet" href="<?php if($this_is_home_page){ } else { echo DIR_WS_TEMPLATE . 'css/ie6.css';}?>" />
<![endif]-->
</head>
<?php // NOTE: Blank line following is intended: ?>
...and now the tpl_header.php file:
<?php // Display all header alerts via messageStack:
if ($messageStack->size('header') > 0) {
echo $messageStack->output('header');
if (isset($_GET['error_message']) && zen_not_null($_GET['error_message'])) {
echo htmlspecialchars(urldecode($_GET['error_message']));
if (isset($_GET['info_message']) && zen_not_null($_GET['info_message'])) {
echo htmlspecialchars($_GET['info_message']);
if (!isset($flag_disable_header) || !$flag_disable_header) {
<?php //echo '<a class="image" title="Welcome to Our shop." href="' . HTTP_SERVER . DIR_WS_CATALOG . '" tabindex="1">' . zen_image($template->get_template_dir(HEADER_LOGO_IMAGE, DIR_WS_TEMPLATE, $current_page_base,'images'). '/' . HEADER_LOGO_IMAGE, HEADER_ALT_TEXT) . '</a>'; ?>
<?php echo '<a class="image" title="Welcome to our Shop." href="' . HTTP_SERVER . DIR_WS_CATALOG . '" tabindex="1"><img src="' . HTTP_SERVER . '/' . DIR_WS_TEMPLATE . 'images/' . HEADER_LOGO_IMAGE . '" alt="' . HEADER_ALT_TEXT . '" /></a>'; ?>
<div id="inner" class="clearfix">
<div class="top left">
<a title="Visit to find yarn by weight." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=1">yarn by gauge</a>
<a title="Visit to find yarn by fiber." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=2">yarn by fiber</a>
<a title="Visit to find by color." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=3">yarn by color</a>
<a title="Browse through all of our available patterns." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=4">patterns</a>
<br />
<a title="Find yarn that is a solid color." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=12">solid color</a>
<a title="Find yarn that has slight variations in color." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=11">somewhat solid</a>
<a title="Find fun, multicolored yarn." href="<?php echo DIR_WS_HTTPS_CATALOG ?>index.php?&cPath=10">multicolor</a>
<div class="top middle">
<a title="Go back to the home page." href="<?php echo (($request_type == 'SSL') ? HTTPS_SERVER . DIR_WS_HTTPS_CATALOG : HTTP_SERVER . DIR_WS_CATALOG ); ?>">home</a>
<?php if (EZPAGES_STATUS_HEADER == '1' or (EZPAGES_STATUS_HEADER == '2' and (strstr(EXCLUDE_ADMIN_IP_FOR_MAINTENANCE, $_SERVER['REMOTE_ADDR'])))) { ?>
<?php require($template->get_template_dir('tpl_ezpages_bar_header.php',DIR_WS_TEMPLATE, $current_page_base,'templates'). '/tpl_ezpages_bar_header.php'); ?>
<?php } ?>
<a title="Subscribe to the Newsletter." href="#">newsletter</a>
<a title="Visit our blog!" href="#">blog</a>
<a title="View our gallery." href="#">gallery</a>
<div class="top right">
<a href="<?php echo zen_href_link(FILENAME_CONTACT_US, '', 'SSL'); ?>">contact</a>
<a href="<?php echo zen_href_link(FILENAME_ACCOUNT, '', 'SSL'); ?>"><?php echo HEADER_TITLE_MY_ACCOUNT; ?></a>
<a href="<?php echo zen_href_link(FILENAME_LOGOFF, '', 'SSL'); ?>"><?php echo HEADER_TITLE_LOGOFF; ?></a>
<?php } else { if (STORE_STATUS == '0') { ?>
<a href="<?php echo zen_href_link(FILENAME_LOGIN, '', 'SSL'); ?>"><?php echo HEADER_TITLE_LOGIN; ?></a>
<?php } } if ($_SESSION['cart']->count_contents() != 0) { ?>
<a href="<?php echo zen_href_link(FILENAME_SHOPPING_CART, '', 'NONSSL'); ?>"><?php echo HEADER_TITLE_CART_CONTENTS; ?></a>
<a href="<?php echo zen_href_link(FILENAME_CHECKOUT_SHIPPING, '', 'SSL'); ?>"><?php echo HEADER_TITLE_CHECKOUT; ?></a>
<?php }?>
</div> <!-- /inner -->
</div> <!-- /header -->
<?php } ?>
I'm positive that, if there's errors in the code, it's in one of these two files. (hte "blog" and "gallery" are what will be the two links that need hard-coded to an outside URL eventually.) Do you (or anyone) see anything weird there?
