That's the problem... I would like the category to be pre-selected and based on the category that the user is currently in. If the user is in a top level category, then it would filter based on all the products down the chain.
http://www.bedsideplaythings.com - WARNING ADULT
I wish I could help. I am no programmer but I kow SQL. Using that i was able to fix the logic in the code earlier. But for you problem someone who knows php will have to help. Good luck!!
maybe i don't understand what this addon does, but i installed it (on my local setup) and i can't see the change any where... where is it supposed to show up (search results? a sidebox?) the readme file included in the download only had instructions of what to add to the english.php and maybe were incomplete?
i'm hoping it allows search results or product list to be filtered by cateogories. i don't use attributes, but i suppose price would be a nice thing to be able to filter on too...
is there something i'm supposed to turn on in the admin?
thanks.
:) emily
http://store.inspiritcommon.com/
ZC 1.3.8a on Godaddy :: EP 1.2.5.4 :: Adv Search 1.1 and a buncha other stuff
I have this addon working well locally with several attributes such as Size, Color etc.
Instead of showing the Attribute title at the top of the Attribute drop down lists my client wants to show Please Select.
Can someone please help and show me what I need to edit to make these changes.
Hi everyone!
What a buggy add on!
I got it to work fine, that is until I add some more price ranges with extra PRANGE statements.
I amended 3 files and added more PRANGE statements
My header_php.php was amended with:
My product_filter_defines.php amended:PHP Code:$enable_price_filter = true;
switch($price_range){
case 0:
$pfrom = MIN_PRICE;
$pto = MAX_PRICE;
case 1:
$pfrom = PRANGE1_MIN;
$pto = PRANGE1_MAX;
case 2:
$pfrom = PRANGE2_MIN;
$pto = PRANGE2_MAX;
case 3:
$pfrom = PRANGE3_MIN;
$pto = PRANGE3_MAX;
case 4:
$pfrom = PRANGE4_MIN;
$pto = PRANGE4_MAX;
case 5:
$pfrom = PRANGE5_MIN;
$pto = PRANGE5_MAX;
$pfrom = PRANGE6_MIN;
$pto = PRANGE6_MAX;
And finally my tpl_product_filter.php:PHP Code:define('MIN_PRICE','0');
define('MAX_PRICE','1000000');
define('PRANGE1_WORD','Below 10');
define('PRANGE1_MIN',MIN_PRICE);
define('PRANGE1_MAX',9.99);
define('PRANGE2_WORD','10 -- 20');
define('PRANGE2_MIN',10.00);
define('PRANGE2_MAX',19.99);
define('PRANGE3_WORD','20 -- 30');
define('PRANGE3_MIN',20.00);
define('PRANGE3_MAX',29.99);
define('PRANGE4_WORD','30 -- 40');
define('PRANGE4_MIN',30.00);
define('PRANGE4_MAX',39.99);
define('PRANGE5_WORD','40 -- 50');
define('PRANGE5_MIN',40.00);
define('PRANGE5_MAX',49.99);
define('PRANGE6_WORD','Over 50');
define('PRANGE6_MIN',50.00);
define('PRANGE6_MAX',MAX_PRICE);
Whenever I search based on the original 5 PRANGE I have no issues its when I try the range specified by the new 6th PRANGE that I get this error:PHP Code:if(SHOW_PRICE_RANGE){
$prices = array (array("id"=> 0, "text" => PRODUCT_FILTER_TEXT_ALL_PRICE),
array("id"=> 1, "text" => PRANGE1_WORD),
array("id"=> 2, "text" => PRANGE2_WORD),
array("id"=> 3, "text" => PRANGE3_WORD),
array("id"=> 4, "text" => PRANGE4_WORD),
array("id"=> 5, "text" => PRANGE5_WORD),
array("id"=> 6, "text" => PRANGE6_WORD));
$content .= zen_draw_pull_down_menu('price_range', $prices, (isset($_GET['price_range']) ? $_GET['price_range'] : ''), '') . zen_hide_session_id();
Also if you look at my page www.majesticsilver.co.uk/store1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'AND p.products_price <= AND p.products_quantity > 0 AND p.products_id = pd.pro' at line 1
in:
[select count(distinct p.products_id) as total FROM products p, products_description pd, products_to_categories p2c, products_attributes pa, categories cat , products_options po , products_options_values pov WHERE (p.products_status = 1 AND p.products_id = pa.products_id AND p2c.categories_id = 66 AND p.products_price >= AND p.products_price <= AND p.products_quantity > 0 AND p.products_id = pd.products_id AND p.products_id = p2c.products_id) ]
you will see that the drop down fields for the filter search are all different sizes and spill over to my center column.
So any Ideas how I can edit the PRONGE properly, what am I doing wrong, cant be an issue with the rest of the code because if I dont add extra PRANGE everything works great. Even with the new PRANGE the original 5 work fine! just the extra one makes an error.
And which file to edit to control the width of the drop down fields..
Kindly assist me on this
P.S. Anyone posting some examples of working code would be really nice- Cheers!
P.S. JABBAWEST
I just took a look at your amazing website so pretty! and what beautiful jewelry you have!
Myself im more into the silver/budget range.
I see on your website the filter choices dont include any price ranges. Did you simply give up on that due to the PRONGE issue? I thought you had it sorted... please let me know![]()
Update: I sorted out the form field spilling over to the center column issue. All it was a bit of CSS tinkering.
I found the ====forms==== section of my stylesheet and I made the following change/addition to this line
Also width:120px; worked the same for my page... so GREAT!PHP Code:input, select, textarea{ font-family:Arial, Helvetica, sans-serif; font-size:12px; color:#f42fdb; line-height:normal; width:80%;}
But what about the PRONGE issue, jabba? anyone?![]()
Another thing...
Im trying to change the submit button....
I defined
define('BUTTON_IMAGE_PRODUCT_FILTER', 'button_search.gif');
In both
/includes/languages/english/button_names.php
AND
includes/languages/english/extra_definitions/template29011/product_filter_defines.php
but then I need to edit this code in :
includes/templates/template29011/sideboxes/tpl_product_filter.php
Im no programmerPHP Code:$content .= '<br /><input type="submit" value="' . BUTTON_IMAGE_PRODUCT_FILTER . '" />';
I tried putting a reference to the image but i see other templates use something like
I tried many combinations and nothing works how do I incorporate a Div Class into the $.content statement. or is there a better way to do itPHP Code:<div class="buttonRow forward"><?php echo zen_image_submit(BUTTON_IMAGE_LOGIN, BUTTON_LOGIN_ALT); ?></div>![]()
Ahhh the life of a zenner aint an easy one![]()
Wouldn't it be simpler to save the new button_names.php to includes/languages/english/template29011/button_names.php?
That's what the override system is all about.![]()
